What kills motorhomes? (1 Viewer)
Jan 19, 2012
638
623
Leicester
Since 2012
Mine is a 2007 Autocruise Starseeker. It is, so far as I can tell, in perfect condition, and has done some 25,000 miles. But mileage seems a false indicator for 'vans - if it had been made into a delivery van I'd expect it to go round the clock a couple of times at least. There isn't much metal to rust and the chassis has been waxoyled. So what ages it and will eventually kill it off?
Perhaps it's using it - maybe we should record occupancy days, as being more important than mileage. Or even not using it - should we make a note of how much we DON'T use it? It's a serious question as I want to keep this van for a long time. What strategy is best and what is to be avoided?
Feb 9, 2008
4,093
5,910
SW Scotland
LP Coachbuilt
Since 2008 after caravanning for 20 years
I reckon not using a van is worse than using it, okay, you'll get wear and tear more than if it's idle but like a car, it's meant to go.
Rgds
Bill
Feb 16, 2013
19,735
52,035
uttoxeter
ambulance conversion
50 years
Mines a 07 as well with 31000 on the clock, but aren't planning on ever buying another, don't see why it shouldn't go on for years, as it's still same as new inside and as you say mechanicals should be good to go round the clock easy, so don't see any probs , look at how many vans are about from the eighths and nineties it'll need wear and tear stuff but don't they all:cry:
scotjimland
2,335
10,108
A Woosh bang
Mine is a 2007 Autocruise Starseeker. It is, so far as I can tell, in perfect condition, and has done some 25,000 miles. But mileage seems a false indicator for 'vans - if it had been made into a delivery van I'd expect it to go round the clock a couple of times at least. There isn't much metal to rust and the chassis has been waxoyled.[HI] So what ages it and will eventually kill it off?[/HI]
Three things
Damp, damp, damp..
everything else can be maintained, repaired or replaced.. .. but if damp gets a grip and the rot not dealt with... kaput.. it becomes too expensive to repair.. unless it is a classic and has intrinsic value.
Oct 28, 2013
490
443
Lincoln
Van Conversion
Three things
Damp, damp, damp..
That's a fact Jim but also leaving it idle for weeks or even months on end will do for it in time.
Like all things mechanical, once they've been run for the first time they need to be used on a regular basis otherwise brakes / clutches seize, batteries can drain, oil seals dry out and leak and cylinder bores rust.
Use it as regularly as possible would be my advice.
geo glasgow
292
274
Glasgow
Auto-trail cheyenne
i had a wee bit bit of a leak
Three things
Damp, damp, damp..
i had a small leak
for a couple of weeks i had a leak from the large skylight on the roof,
sussed it and sorted i even popped it fully out got into the roof cavaty pulled out slightly damp but not bad insulation ,refilled once i dried it out,
resealed and complete, good job done,
however there is no smell or damp i have checked however does anyone recommend a good dehumidifier on the uk market for around £100 mark,
thanks
Nov 3, 2013
3,170
9,386
Portugal
Fiat Ducato Auto Wildax
C/van since '73 .M/h.2009
Hi.
If you are very,very careful, you could...... LOVE it to death:winky::winky::winky:
Tea Bag
E
Jan 19, 2012
638
623
Leicester
Since 2012
Damp...what causes the ingress? I'm careful about keeping everything inside aired over winter, but what else is likely to create conditions where damp can appear?
Mastercamper
578
1,955
Northumberland Flag Flier
Van Conversion
50 years campervanning
This is absolutely spot on. :thumb:
Laying up for the winter is the worst possible scenario in my opinion.
Regular maintenance, lubrication and a good coat of `looking at` are also v. important.
Diesel engines thrive on hard work coupled with sympathetic maintenance.
Most important is to enjoy it, and the freedom and new horizons associated with it.:winky:
scotjimland
2,335
10,108
A Woosh bang
when driving over rough uneven ground the body flexes , we've all seen it, a wooden frame will twist and flex.. this can and will eventually open up wall joints. ..
It will depend a lot on the type of construction.. a metal or fiber glass box is less likely to leak than a timber framed box clad in aluminum ..
damp comes in through bad joints.. as they age the sealer hardens and cracks.. body joints, window seals.. around any piece of roof furniture.. especially roof lights.. (walking on the roof can cause leaks around roof lights). and just about anywhere the walls have been cut to fit something.
You rarely find damp in a fibre glass roofed vans or panel van conversion.. and if there is damp, it is less likely to cause irreversible damage.
Prevention is always better than cure.. body and window seals should be looked at every year and if required replaced by removing the old mastic and redoing.
so.. for me at any rate.. my first choice of van is a fiberglass construction..
my last European van had a fiberglass roof and walls.
daisy mae
675
597
Leicestershire
C class Coachbuilt
I`m a newbie, now 1 year
I am hoping that my monoquoc sp body MH will last me , had new windows fitted when I bought it, so should be fine on the damp issue, have seen bad water ingress in the first caravan that we bought in 1989, cost over £2000 to put right, did last for many years afterwards, but when it came to a MH I went the grp route and so pleased I did.:thumb: I am looking after it, mechanically as well as inside.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
Has to be lack of use that kills them.. Mechanically anyway.. Not experienced damp thankfully.. I don't really expect to by regular use and maintenance
cruiser
4,220
4,952
northampton
coach built elddis 400
since 1978
I keep my at home so have a elec lead to it .and put a small heater in it to keep it dry .as some one has said don't let it get damp.i have had mine from new.1990.and it is still going well.24 years new.:thumb::thumb:
maz
Jan 26, 2011
4,460
7,740
Bizeljsko, Slovenia
N+B Arto
Since March 2011
I am firmly of the opinion that it is cycling that kills off motorhomes. All that bouncing about of bicycles on racks each time you go over a bump - that back wall is going to give way at some point. :RollEyes:
Then there's the buildup of static electricity throughout the van, caused by the persistent wearing of lycra. Combine that with a teensy-weensy leak of LPG or a gassing battery - BOOM! :Eeek:
It has been established that the main cause of damp in motorhomes owned by cyclists is the excess humidity produced by sweaty lycra, combined with the washing of said lycra and hanging it in the shower to dry. :wub:
Hope this helps! ::bigsmile:
cruiser
4,220
4,952
northampton
since 1978
oh good lets all run the bikers over.no more damp.well a few tried to get under the wheels of my trucks over the last 40 years.not got one yet.oh well never mind.:ROFLMAO::ROFLMAO::ROFLMAO:
Feb 16, 2013
19,735
52,035
uttoxeter
50 years
I know this was only in jest but bike carriers must strain something, there was one on mine but when I saw the flexing with a bike on I took it off, and never put it back.
Il manage without biking anymore::bigsmile:::bigsmile:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Warmth inside will not stop Killer Damp. I know. Our damp was in the side wall bottom rail inside a locker. Water got in at the joint between the wall and the side skirt, as intended by the Germans, though the Germans had hoped it would run away from the wood but their thin plastic DPC seal did not work.
Buy a damp meter and use it everywhere including underneath.
Catch it early and it's relatively easy to cure.
But "24 years on", you've got a good 'un there.
