What gearbox for a Smart on A Frame (2 Viewers)
Traveller_HA5_3DOM
422
323
Following the Sun
Hobby Premium 65GE
since 1985
Foud out a little more on this Auto box. It is a Gertrag box and seems to have three gear trains and two wet clutches. It also claims to be able to select lower gears in a non sequential way. It should have first and reverse available when neutral is selected and that will need manual selection. It would also seem to have some sort of free wheel device built in when you lift off the throttle, to aid the mpg figures. So until more technical information emerges anything is possible.
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
Possl 636 FR panel van
1994 and beyond...
Do you mean latest model? This far superior suspension/ride quality and auto box. Which were the downsides on earlier models
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Not too complex Tony..
There are some easy ones that partially work such as delipping the air intake which fools the air speed sensors and smooths out changes, and you can change things quite a bit with a different program
You can also stop some of the surging by changing the length of the actuating arm from the clutch solenoid but that is a bit of a pain as you really need to pull the box off to do the work
Do you know which tic pipe you have ?
Everything is OEM - I haven't done anything other than remove the clutch actuator, re-lube its internals, and adjust to the standard marks. 'tic' I assume is turbo intake?
Jaws
23,836
72,493
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Yes Tony...
Have a look at fitting one from the Brabus model.
It is smoother on the inside so again reduces surging
It is a strange thing but the way Smarties work most gear change issues are related to air intake (y)
Minxy
32,659
66,565
E Yorks
Carthago Compactline
I'm not into all this 'technical' stuff with regard to changing this and that on Smart ForTwo's to 'improve' the gear changes, which I don't find bad at all in auto mode anyway ... I find that if I just lift my foot very slightly off the accelerator at the time I know it will be wanting to change it does so lovely and smoothly, but even if I don't it's very good anyway.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
You're right they aren't bad driven as intended. I never use ours in Auto mode though and it is worth knowing that one way a Smart smooths gearchanges is by easing the clutch - too much IMO when accelerating hard. I'm always conscious of the effect on clutch life of too much deliberate slip. One thing that works brilliantly is the ECO stop/start mode. It's very smooth and unobtrusive and as a bonus has an in-line starter motor. Very sophisticated :).
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Yes Tony...
I'll do that. Intake air flow isn't the first thing that springs to mind when investigating gearchange quality:).
Judge Mental
Sep 2, 2009
6,650
5,883
Sarth London
1994 and beyond...
If you buy a new one i think the choice should be a manual for A framing
Minxy
32,659
66,565
E Yorks
If anyone has a 451 model it's worth ringing a dealer and checking if the ancillary belt change has been done - this is the ONE thing for which there is a known 'fault' so they are changing the belts for a different one FOC, you just need to book it in with them, they can check on their systems so worth asking.
The reason for the problem is that the MHD system puts a lot of strain on the belt and the retaining bolt due to the continual stopping/starting of the car, this can cause the bolt to move/wear a bit and allow the belt to become misaligned which then causes it to shred ... I know 'cause it did this on the first white one we had when, after driving it home all the way from Wales, it went kaput 7 miles from home! If the belt ever DOES go, and you'll certainly hear the noise when it does, stop immediately and do NOT be tempted to try to continue as you won't have any oil circulating round the engine so it will boil! Once the fix is done though there's nothing to worry about - I hasten to add this doesn't happen with all of them but Smart have decided to change the belts FOC regardless and the car doesn't have to be under warranty at the time either.
