What does this switch do? (1 Viewer)
simbadog
1,683
3,337
Wengen
A/S Broadway EL 2021
Since 2010
Hi, Autotrail 634 2007 with Fiat Ducato base.
I can't work out what the rocker switch does? It's the round one to the left of the air vent.
Thank you :smiley:
R
Robert Clark
If its got an alarm, my guess would be that the switch disables the interior sensor and siren
OR dims external flashing LED's
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
My MoHo has a growler alarm and I have a rocker switch like that to activate a bike rack "loop". A cable that plugs into a socket underneath of the van and then through a valuable piece of kit (bikes, generator, Bottle crate, etc).
Badknee
7,407
412,780
notloB
Vantage Neo
Living the dream.
Be careful with that switch. It activates the passenger seat ejector rockets, now you wouldn't want to accidentally shoot the wife out now would you ............... :cautious: ............. Or would you? :whistle::LOL::LOL:
simbadog
simbadog
1,683
3,337
Wengen
Since 2010
Thanks, It does have a toad alarm system, perhaps it does have something to do with that?
I don't however have any instructions for it!
kelv
672
895
leicester
Carthago 145
I have two switches one operates my alarm loop as popeye mentioned and the other turns on my movement sensor for the tracker
Zigisla
2,580
3,106
Gosport, Hants
Sunlight A72
Getting better month by month.
Switch it on. Arm the alarm, then move around inside if no alarm, then switch off, arm the alarm move around inside, if alarm sounds, found it!!
If no difference, switch it on and use MH as normal til something doesn't work, then switch off if it works, found it!!
Mar 16, 2010
3,057
30,742
Carmarthenshire
In between
Since 1988
We had the same on our 2012 Autotrail Tracker it was to disable the internal sensors as Robert Clark said but I seem to remember it had to be done in a sequence and sorry I can't remember what the sequence was.
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I have the same but it is located in the glove box
And when we got the van it had no alarm fitted
simbadog
simbadog
1,683
3,337
Wengen
Since 2010
Thanks, I have the 2 Toad fobs & have to press one of the buttons to disable the immobiliser before starting.
I don't know the sequence for other buttons on there or indeed even where the alarm is located!
It is definitely a Toad as fobs are thus & there are stickers, also has a PIR in lounge area, could do with some
instructions but will have to find model first :(
The Dotties
1,872
4,022
Gloucester
In between
Ex Newbie
I've got one of those. Normally the reversing camera comes on in reverse gear, but can be overridden to stay on when shunting about.
Jaws
23,836
72,484
Thetford Norfolk
C class, Chieftain
As mine is on the passenger side I am completely baffled .. Next time I do any work on her I will check to see where the hell the wires go !
Debs
6,302
181,620
West Notts
A class Adria Vision
:LOL: Looks very like a pic I posted last year when we hadn't had the van long.....
.....eventually found out it worked the spotlights:D
WAG2CRU
376
495
Argyll
Hymer B654SL Star Edition
since2012
That is an aftermarket accessory switch, nothing to do with the Fiat bit, so fitted by the converter or for an accessory. Could be anything, we have one which switches power to the media centre when the ignition is off. Trial and error, do you feel lucky? ;)
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
What a bl***y good idea :clap: I shall be fitting one of those :cheers: Cheers
TheBig1
17,630
43,279
be careful how you wire an override switch for the reverse camera as i have seen one van where it also switched on the reversing light without reverse gear selected
Apr 10, 2010
552
544
Bedfordshire
Carthago
Since Sept 2003
Good point, big1, thanks for the warning.
D
Deleted member 29692
It's just a bog standard rocker switch with a neon. It could do almost anything.
DanielFord
3,020
3,086
Do you know what, I am going to fit a random rocker switch somewhere in our van (that in truth does nothing) so that when we come to sell it, I can look out for the "what does this switch do" thread pertaining to my old van :D
