What do I need? (1 Viewer)
Jazzbow
146
77
West Scotland
new
Howdee chums! I have a tv that works off mains and 12v. I need the lead with the cigarette type plug at the end to go in to the adapter in the photo. I have googled and googled but I'm stuck... What's it called please?
Link Removed
Sorry I couldn't seem to attach the pic :Doh: but that is a link to it.
Many thanks
Dawn
Link Removed
Apr 9, 2013
663
373
Ayr
Newbie
Link Removed
Many thanks
Dawn
Link Removed
Um, that's a mains adapter that takes a "kettle type" plug. You can't feed 12V into that.
You need a lead that matches the 12V socket on your TV. If that box is a "mains to 12V" adapter then you want a lead that has a cigar lighter plug (or whatever kind of 12V plug you have in your van) and a plug that matches the plug on the end of your mains adapter that plugs into your TV.
Could really do with a better picture of that plug, not the mains socket on your power adapter.
Tim
rainbow chasers
3,680
1,725
Mid Cornwall
Various
You would be best getting a voltage stabiliser such as Amperor. This would give your 12v, but stabilise the power and avoid spiking, this enables you to run off generators and the like without damaging your TV. About £25 IIRC
Jazzbow
Jazzbow
146
77
West Scotland
new
Tim
hahaha, no wonder I couldn't find it... it doesn't exist!
Broken Link Removed
is that what I need?
Thanks for super speedy replies as usual :thumb:
663
373
Ayr
Newbie
:Blush:
Broken Link Removed
Hard for me to tell without seeing what your plug looks like but it certainly looks similar to yours. Only you can be sure if it's the same. That said, I doubt there are that many varieties of plug and if it looks the same, I reckon you could safely order it.
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
usually either a 2.5 'DC' plug is fitted .. Pretty standard stuff
One of these..
Link Removed
Though I am sure there will be others cheaper, that one has reasonably thick wire so will be able to handle the 3+ amps the average tv draws :Smile:
Jazzbow
Jazzbow
146
77
West Scotland
new
One of these..
Link Removed
Thanks, the telly definitely has a four pin socket, do I need to worry about the thickness of the wire now? >Think I'd be better just taking a book LOL!
Apr 9, 2013
663
373
Ayr
Newbie
I think you've found the right lead (which is rated at 5 amps). Just go for it! ;-)
Jaws
23,836
72,489
Thetford Norfolk
C class, Chieftain
Ahhhh... Okkkkkkkkkkkkkkkkkkk
So, starting from scratch
You have a power supply unit that plugs in the mains.. The output from that is 12v so you can use it ( in theory ) on the battery in the van..
BUT !!
The socket that the lead from the PSU ( power Supply Unit ) plugs in to is a 4 pin jobby..
Hope thats right ?
If so you really need someone to assist who knows what they are doing.
I personally simply cut that lead, figure out which wires are the 12v feed and their polarity, then put a two pin non-reversible plug and socket on the cut ends, the female going on the 'live' side.
I also make up another lead with another female on one end and a cigar type plug on the other
That way I can use the tv on either mains or battery
Having said all that, if the tv is only going to be used in the van there is absolutely no need to keep the original PSU as it will never be used.
If your on hookup then the batteries are being charged anyway, so you can ALWAYS run on the 12v system :thumb:
Apr 9, 2013
663
373
Ayr
Newbie
BUT !!
Hope thats right ?
Ooo, that sounds way complicated, and without meaning to insult anyone, probably beyond the OPs capabilities. Even though I'm pretty handy with a multimeter and soldering iron, I think I would still prefer the two separate leads option.
Still, at least the OP now has a range of choices open to her now. ;-)
Tim
Jazzbow
Jazzbow
146
77
West Scotland
new
Tim
No offence taken! :ROFLMAO:
I got this : [ame="http://www.amazon.co.uk/gp/product/B008A6B89I/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1"]4 Pin type 12V 5A car / caravan cigarette lighter power: Amazon.co.uk: Electronics[/ame]
It works fine and says that it stops fluctuations too.
Thanks for all the responses :thumb:
