What Battery to Battery Charger to Buy? (1 Viewer)
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
What manufacturer? What amp charge rating?
What should I expect to pay?
The battery bank will be 220 Amp Hours.
Base vehicle is a Fiat Ducato 250 Maxi 3 litre 2010 and it will be a 12 volt system.
scotjimland
2,324
10,061
A Woosh bang
Worth reading..
http://www.motorhomeplanet.co.uk/archives/3603
in particular this paragraph
The B2B charger is a serious piece of kit that does a good job. However, it is not cheap and it does need to be installed as part of a balanced, well-designed system. Its fast charging regime also means that open lead acid leisure batteries (and starter batteries?) will need to be topped up fairly regularly, due to losses from gassing.
Price: At the time of writing, Sterling Power is selling the BB1250 model that most motorhomers would choose for £349. It was considerably cheaper when I bought ours but it still cost us around £200, a couple of years ago. This makes it a pretty expensive battery charger.
12V System Design: The second consideration when choosing a B2B charger is that it is a powerful piece of equipment that can place a heavy load on your van’s electrical generation system.
What this means is that if your leisure battery is too heavily loaded for too much of the time, the B2B charger will transfer that load onto your van’s alternator and starter battery by maintaining a very high rate of charge for long periods of time. Based on my experience with the charger, I can envisage situations where this might cause problems. This is one reason I would recommend that you fit the alternator temperature sensor.
Jaws
23,836
72,479
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I have used the Cak Tanks little jobby for the past 7 or 8 years on all my vans, my sons vans and my daughters..
About £30 and as easy to fit and using a knife and fork..
Reactions: JJ
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
Well I have the B2B fitted and have for past 2 years and it works great. It charges my 330 amps worth of batteries in no time. Trouble free to date and the article above is dated 2010. I would have thought if there was a problem Mr Sterling would have gone bust by now! as they are fitted not just to MH's
scotjimland
2,324
10,061
A Woosh bang
http://leisurelines.net/battery-charge-manager-leisure--main-battery-3334-p.asp
basically both the same as Vanbitz battery master
but it's not what the OP is asking about.. completely different animal
Charlie
3,211
3,639
Auto Sleeper Kemerton.
Im a newbie
scotjimland
2,324
10,061
A Woosh bang
jonandshell
5,476
8,299
Norfolk
Not got one!
Since 2006
Sterling, definitely.
Rating? 50 Amps will be ideal, but a bigger one is the same price and allows for a bigger battery bank upgrade.
Your batteries will only absorb what they are capable of and an oversized B2B won't cause any problems.
B2B chargers work best with open lead acid batteries and their benefits diminish with AGM and gel types.
Oct 8, 2014
1,639
3,027
Wiltshire
Autotrail Excel 600B
Previous VW Camper + Caravan
I have just fitted a CTEK D250S Dual. http://www.ctek.com/gb/en/chargers/D250S DUAL
"The D250S DUAL is a fully automatic 5-stage charger that supplies 20A to 12V batteries of 40-300Ah. The charger is IP65 classified (water jet and dust protected and approved for outdoor use), protects vehicle electronics and is suitable for all types of lead-acid batteries (Wet, MF, Gel, AGM). It is supplied with a 2 year guarantee."
It doesn't have the same output as a Sterling unit (only 20 amps), but is significantly cheaper.
Edit .... the addition of the add-on SMARTPASS unit, caters for 80 amp charging of battery banks up to 800 Ah
I don't spend a lot of time "off grid" but the main benefit for me is that it charges the leisure batteries more efficiently, and should prolong their life. It also has an integral MPPT Solar Controller for the leisure battery, and will keep the vehicle battery topped up from solar.
I believe CTEK have a good reputation, although the first unit I received was faulty...... replaced within 48 hours, by Amazon.
I am still in the process of installing my solar panel ... I have tested it loose, beside the van and it all works fine. I have noticed that since I fitted the D250S, my leisure batteries are charged far better after a drive than they were with the standard split-charge relay.
Abacist
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
Well as you might have noticed from another thread I have made up my mind and done the deal on a selection of stuff. I have not yet sold my Autotrail but am not prepared to have another month long holiday with an inefficient and inadequate electrical system.
I have bought the Sterling 50 Amp B2B as I won a brand new one in an Ebay auction for much less than their normal retail price. I also bid on one of their pure sine wave inverters but didn't get it so bought a chinese one sourced from Germany and chose a 1500 watt model with a max rating of 3000 watts. The idea is to have a separate system to provide mains electric when we are off the grid for anything that we want to plug into it. I am not wiring it into the van to be available from any socket as the van is going to be sold and all this will be removed ready for the next one. It will also supply 12 volt power in the hab lounge area which has no available 12 volt sockets and the cab ones are dead unless the ignition is on.
I was originally going to use the matched pair of original van electrosols which I had replaced so these were sat idle in the garage but still charged up. Sod's law took over and one has now given up the ghost at 6 years old so I have bought a matched pair of Varta LFD 180's as these are sealed units and can be used in the hab part of the van by all accounts as they don't gas or if they do its sealed. Charging will only take place when we are driving or the engine is running and at night there will be plenty of ventilation in any event as we sleep with all the roof vents open and windows when its hot. I have no plans to add more solar to the van before I sell it so the existing solar panel charges the existing van systems via the Sargent.
I have been buying the serious cables and fuses required to wire this lot together and planning the installation as not everything has yet arrived. Part of the purchases includes an 8 ton rated pair of hydraulic terminal crimpers - Good old Amazon! I should get it all done before we go away in 10 days time - here's hoping! I have promised the wife that she will be able to dry and curl her hair when we are not on a hookup and she remains sceptical so that makes me even more determined to get it all done!
I have also bought the book "Managing 12 Volts - How to upgrade, operate and troubleshoot 12 volt systems" written by Harold Barre an American so talk of mains electric needs to be doubled from 120 volts to 240 volts but apart from that its aimed at RV'ers and yachtsmen and is a handy and easy read with lots of guides on how to plan and design or upgrade your system - again from Amazon.
Many thanks for all your contributions and I would say that I already have a Vanbitz battery master so that the cab battery always gets a trickle charge when we are on a hookup. How can people get away with designing such poor systems that only do half a job and you have to buy a shed load of stuff to make it remotely useful!
Riftzoner
34
54
Whitby Cheshire
Pilote P696D
Completely agree, Pilote have also completely missed the mark for 2021, my new 2021 P696D Evidence suffers from the Chassis Battery going flat within 10 days because it only gets charge (80%) from the (not so) Smart Alternator whilst the engine is running, as they haven’t included anything to draw charge from either the EHU or Solar when vehicle is parked up! Apparently they did have a ‘Top up’ Booster but had problems with it, so they just deleted it, even though the Booster remains included in the specification, the brochure & handbook!
I know this is a little off track to the original thread but bang on as per the quote!
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
If you're one of those weird people that 'read books' there's a couple worth thumbing through.
and there's a load of further info on the 'Technical Information' section of their website.
They do a real hardcopy printed version as well, if you prefer that to the PDF.
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
If you're installing an off-grid system in a house, you quickly come to the conclusion that a high-power inverter is best supplied by 24V or 48V, rather than 12V (3000W = 12V 250A or 48V 62.5A). Your 12V habitation electrics usually only takes 20A max, ie 12 x 20 = 240W. So is it really worth all that heavy-duty copper and voltage drop worries, to keep everything at 12V? It might be better to have a big 24V or 48V battery, B2B and charger, plus a small 250W 48-to-12V converter to supply the habitation loads.
I know you've already bought the stuff, but worth thinking about.
Abacist
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
I do appreciate your contributions but my original post was just over 5 years ago and I have since changed vans. I still have my Sterling B2B powering the 2 big Vartas, separate from the 2 smaller Hankook 110v has batteries, charged by solar, split charge relay or CBE mains charger and Victron energy large inverter for mains supply when off grid. I have recently added the bluetooth devices to make the solar controllers "Smart" and also the shunt so that I can get all the details on my smart phone. I don't think I'll be converting to 24v or 48volts soon!
Unfortunately the house is the wrong way around to employ solar on the roof and the wife thinks that they are ugly things but she can't see the two on top of the van and she does like to use the hair dryer etc when we are off the grid!
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
I usually spot the old threads but when someone replies to an old thread with a new comment, it's easy to miss.
