whale waterfill
Discussion in 'The Beginner' started by jgee, Aug 17, 2010.
  1. jgee
    jgee Read Only Funster
    Dec 21, 2009
    85
    wigan
    the system works fine but ineed to puta water container on a small step as the pump submersable will not reach if water container left on floor surely you dont need to lift water higher seems abad idea
  2. IrasciBill
    IrasciBill Funster
    Mar 6, 2010
    187
    20
    SW Scotland
    Yes, we have the same problem - obviously depends on how high up your filler is! :Eeek:
    However, we only use the submersible for adding water treatment etc. Normal water filling is done with a Whale flat blue hose which has the adaptor block on one end. Ours came with the van but I think they're quite pricey! :Sad:
  3. Johns_Cross_Motorhomes
    Jan 5, 2008
    9,360
    5,377
    East Sussex 01-580-881288
    Is this what you have got, sorry do not know the hose length.
    Whale Ep8812 Watermaster Plug and Pump
    Peter
  4. keith
    keith Funster
    Aug 25, 2007
    3,285
    1,671
    Ecclefechan
    We have one similar & the length is just the right distance from the filler to the ground. :thumb:
    Seems to me the motor home manufactures should make sure it's long enough to reach the filler fitted to the motor home with the water container on the floor.
    It's not rocket science is it? :Doh: Just another item they don't bother to think about when designing it.
  5. jgee
    Dec 21, 2009
    85
    wigan
    whale pump
    the overall length is 4ft the only referance to a model no it says whale premium pump 12vdc looks same as your photo
