Can anyone explain the above plates to me and the apparent differences between the German (ALKO) plate on the right and the Fiat plate on the left. Thanks in anticipation.
Go by the AlKo plate on the right ;
4500Kg = Total allowed weight of m/h
6000Kg Total weight when towing (max wt of trailer = 1500Kg)
2100Kg Max front axle
2500Kg Max rear axle
That's a different matter .......... if you are registered at 4250Kg then I would say that is your current max weight although ig you get weight checked on the road they will probably go by the Al-Ko plate at 4500Kg so should not be a problem.The V5C says 4,250kg
I weighed our Chic on the way back from collecting her but we had been staying in her for a week so had some kit on board.Hello Richard,
Just out of interest do you know the actual weight of your vehicle prior to loading?
