Weight advice please (1 Viewer)
Nik
Oct 29, 2014
359
238
Cornish exile in Surrey
Autotrail Delaware
1 year
Hi I have put my 2012 Autotrail Delaware over a weighbridge and have the following results. Front..1540Kg. Rear..3840kg All...4120kg
There are 2 plates under the bonnet
1. Fiat states 4250
6500
1.............2100
2.............2400
2nd plate (Autotrail 2nd stage conversion)
4250
5290
1...............2100
2...............2400.
I had a full watertank, nearly full diesel, 2 bikes and tow ball carrier. Some food and wine, not too many clothes, general kit including drive away awning, just me on board, my wife who claims to be not too heavy was outside directing.
I hope I'm reading the plates wrong but am I overweight on the rear axle? If so I don't know how to shed that much weight, 1440Kg. Should I consider getting it up plated.
advice please, thanks
nik.
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
According to your figures your rear axle is overloaded by about 1.5 tonnes:Eeek:
However their is a problem as the weighbridge figures don't add up.
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
I agree with @DuxDeluxe - the figures just don't add up! Front+rear should equal total. The rear figure MUST be wrong!
If we assume that the other two readings are correct then the rear will be 2580 - which is still overweight. Uprating the max and the rear sounds like it is worth investigating.
Clickem
1,034
1,073
Northumberland
None
7 years
The weighbridge figures will not add up to the exact total, as the van is driven on and off, it tilts and weight is added to the lower end
Your individual weights add up to over 5000kgs, far too much compared to the total weight
Needs to be weighed again
Abacist
3,733
10,691
Devon
N & B Arto 88F Tag
since 2013
I suspect a typo on your recorded weights. The rear axle can't be right but it might be as the front looks too light to me and too much weight on the back is making the front light. At worst I hope its not even 2840 kilograms. The best rear axle you are likely to get is 2,500 kilos with a maximum weight upgrade. I have an Autotrail Savannah and have an overall maximum of 4500 kgs with 2500 max on the rear axle with air suspension and upgraded tyres. You have a bike rack and spare wheel hanging off the back end so you must not overload the rear garage. Put heavy stuff under the seats near the front. Light stuff in the garage like chairs, watering can, hose etc.
I think you need a more accurate trip to the weighbridge. Is it flat either side of the weighing platform? If not then your axle weights will be all wrong.
mike mcglynn
Jan 6, 2008
2,700
32,552
St. Helens MERSEYSIDE
Autosleeper Warwick XL
A long time now
I think your weighbridge figure was incorrect try your local council depot weighbridge and tell them what you require ie. front axle ,gross weight,rear axle I used to operate a weighbridge and you need to drive on and off slowly for the sensors to settle to obtain a correct weighing as has been said the two axle weights should come to or very near the gross weight.
BwB
917
1,170
Suffolk UK
Resting b'twix vans
Since 1990
If 3840Kg was your total weight (instead of the figure you have) this would make more sense and give you a rear axle of around 2300Kg which is more acceptable. Just a stab in the dark as 3840 sounds about right to me given the load you mention.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Rear is more likely 1840. Definitely a screwed reading
swidy
197
445
wakefield
coachbuilt
since 2009
I've just had mine weighed fully loaded for long trip diesel full, water full, gas full. its an Autotrail Cheyenne 696 se front 1510 kg and back 2340kg total 3850kg bang on the mark but that's without the wife in, I don't know how to break it to her that she can't come lol
DanielFord
3,020
3,086
Agree with everyone else, I would assume that the chassis is the 4 tonne Ducato, therefore having 3840kg on the rear axle would me scraping the arse end of the van on the road. I assume this isn't happening, so something is awry!
