DBK
Our 'van has a Webasto Dualtop diesel heater which blows hot air out through three outlets. One in the bathroom, one near the front of the vehicle and a larger one in the kitchen area. The heater itself is fitted in the bottom of the wardrobe and the outlet to the bathroom is on one wall of this enclosure and the main outlet is at the front of the wardrobe at feet height. The one to the front of the vehicle runs along the back of the sofabed through ducting, the others also use ducting but the runs are much smaller. The problem is there is no way to balance the air flow as all the outlets are simple grills and the amount of air coming out of the front outlet is a fraction of what comes out of the others. Here in a slightly out of focus shot is the one in the bathroom. (Prior to cleaning I should say in our defence. )
Webasto make closeable outlets in 60mm and 90mm sizes. I bought one 60mm in white from here: http://www.jpcdirect.com/?shop=shopitems/webasto/warm.air.ducting.and.accessories/index.aspx
There are other suppliers but these were cheapest I could find though I didn't look on eBay. The outlet I bought looks like this:
I thought at first I would have to remove the existing outlet completely but after a few grazed knuckles I realised this isn't necessary. The knurled bezel on the front just springs off if you put a thin screwdriver behind it, revealing the main housing, which in the bathroom is sealed in place.
So I just removed the front from the new outlet and clicked it into place.
I haven't changed the main 90mm outlet which blasts into the kitchen. This is because I have been advised the Webasto is very sensitive to overheating and if the main outlet was closed the heater might overheat and (hopefully) shut down.
There are times when of course we want lots of heat going into the bathroom but at other times I am hoping being able to close this outlet a bit will encourage more air to reached the more distant outlet at the front of the vehicle.
Road test reports to follow.
