Water tank levels (2 Viewers)
movan
21,492
120,753
Moving around
Burstner
since07
What is the most USUAL reason for the control panel saying there is 100% water in the tank when you know for a fact that there isn't, please?
Jun 30, 2010
7,924
27,231
1992 VW Auto sleeper Mono
Since 2005 this time
eerrmm generally it's cause yer transponder is rooted!:laughing::laughing::laughing:
Chris69
52
40
Derbyshire
Coach built
since 2006
My theory is that until the water level drops to the next sensor the reading doesn't change.
The other problem is that the position of the sensors may be incorrect.
If the MH is not level this will affect reading.
Water level indicators are renouned for being inaccurate.
Chris
Nov 6, 2013
3,201
229,725
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
We very rarely take any notice of the readout. They are generally wrong :(
Feb 24, 2013
13,087
101,472
Bolsover, Derbyshire
Hymer S800
not long enough
we cant ever get ours to show 100%, even when it has overflowed back out of the filler pipe best we get is 75%
but do you still have 100% even when completely empty?
That could be because your float is stuck up :D
Nov 6, 2013
3,201
229,725
East Sussex
Hymer B574DL
Well!!!!!!!!:wasntme:
Oct 1, 2013
7,513
19,948
Lanzarote
Nil by mouth
Lots
Have you crashed it and the van's upside down?
movan
movan
21,492
120,753
Moving around
Burstner
since07
I thought I was daft ................. then I read most of your answers and realised it was you lot....:) Thanks all for your responses... Yep. think it cos my van not quite level, or that my sticker up is stuck up.. or the panel not accurate, which I can cope with.
Don't think my van is upside down but one never knows these days... could be the clever manufacturers put the wheels on top of the van instead of the bottom ....
(y)(y)
DuxDeluxe
14,659
72,800
Planet Zog
A woosh bang van
You never know..............
Most of these gauges are hopelessly inaccurate and a rough guide at best. Cheers!
Feb 16, 2013
19,736
52,043
uttoxeter
ambulance conversion
50 years
Ours always says it's full till it's got about enough to wash up a couple of times then it jumps to empty, don't really take much notice of it and fill up whenever we see free water thingy
RS_rob
1,010
669
Turnford
Gauge showing full defo empty :rofl: enything else time to fill up ::bigsmile:
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
What we want is SOLUTIONS! It's no good all of us saying they're unreliable.
The one on my previous old van was spot-on. So I spend zillions on a new 'van and as soon as you put a cupfull of water in it, the needle goes past the full to end-stop! It's not something you can check at the dealership and I can't 'dip' the tank because it's under-floor.
I'm cheesed off with it. It's not just a question of having to leave the dishes till the morning. For me, a lack of water means no toilet flush either!
On my last sortie a few days ago, I had to fill up until it overflowed, then open the drain cock and drain off bucket loads of water until I thought I had the right level for the journey:mad:. I rarely travel with a full tank, coz for me (with a 70 litre tank) it's over 150 pounds in weight!
It ain't good enough!
DuxDeluxe
14,659
72,800
Planet Zog
A woosh bang van
But there are usually sensors only at 25%, 50% and 75% as well as allegedly full and allegedly empty. The manufacturers have to strike a balance between what most people will be happy with and the costs associated with an accurate system, which most people don't think you need anyway........... Most of us don't need a solution, really.
To be honest, I did check out the system readouts on the Pilote and it is surprisingly close. Works for us! (y)
RS_rob
1,010
669
Turnford
I have the solution to for mine:
A clear plastic pipe down the side attached to near the top & bottom of tank, simply open locker door & look (y)
Can I be bothered to tinker with such an arse ache NO :roflmto:
Carol
14,052
112,140
North Wales.
:rolleyes:I just open the door, look at the water tank and say its nearly there, Eddie calls me the water monitor.
17,635
43,358
there is a difference between ideal technology that works correctly and a simple system that+ is cheap and easy to fit. most vans have the cheap version...... a set of brass pins stuck through the side of the tank. as the water level goes up, it covers the pins in sequence making an electrical circuit. simple and effective till the pins corrode
if the gauge constantly says full, its likely a short circuit on the wires on a basic system and a stuck float in a more expensive one
Andy
627
689
East Sussex
A class Hymer
newbie
For 'fresh' water, I just look into tank, my grey water guage I guess is goosed as even after empyting tank, (over proper grid. :)) it still reads over half full. Not to worried as I know its showing that.
PP Bear
7,813
28,811
Kent, UK
Auto Trail Dakota SE
I thought I was daft .................(y)(y)[/QUOTE]
Er, ummmm, errrrrr..................:whistle::rolleyes::oops::think::h::h::h::inlove::inlove::*
11,932
9,092
You need to listen to your van Joy :DI can tell from the sound of the pump before it runs out of water (y)Never bothered to fit gauges -simple solution is turn on tap if water comes out you have water (y)if it splutters your running out and if no water comes out then you have run out -simples :D:LOL:
terry
Oct 1, 2013
7,513
19,948
Lanzarote
Nil by mouth
Lots
terry
that sounds a bit technical.
Is there a user's manual for it?
