Water seeping under bathroom wall (1 Viewer)
Murphy
92
53
Mansfield
Shire Conversion
We have a 130 and we have had a leak at back of fridge, seems the cold pipe had came away from the tap due to possible frost, the tap has a pin which needs extracting and then push the hose connections firmly back into the tap base and push the pin back in to secure the hoses, this is to stop the taps from exploding due to frost it just blows the connections off, your issue could be quite similar ?
Rooky Vanner
Mar 23, 2015
93
122
North Nottinghamshire
Autosleeper Kemerton
Since 1989
Exploration starts today..I shall check this first, many thanks
Gorse Hill
2,364
1,944
Stretford
Burnster Ixeo IT 734
Have you contacted the previous owner, he might be able to help if this has occurred before or he could have an opinion as to what might be the cause
Rooky Vanner
Mar 23, 2015
93
122
Since 1989
Update on Elddis Niagra
Got panel off today and seems to be connector onto hot tap that was leaking with some gusto! pushed pipe back in and now I only have a drip. Pump is not running when system full unless I turn the tap on. YEEHAAAA.
Now, would like to get panel out completely and replace the connectors on the hot and cold to be double sure also the small waste from the tip up sink that empties the trough that the sink tips up into, (if you are still awake) drips badly so I need to seal that.
Question is???? most important, how do I remove the toilet roll holder!! failed miserably today. I have to remove this to lift the rear panel out, we're back to the putting the roof on last syndrome mentioned earlier...
Then, its wet suit off, clothes back on and maybe another small break to test, Canoe and wet suit on standby of course!!
A big thank you to all those people who have helped and been so welcoming. Its worth buying a motor home just for this forum, thanks again to all.
scotjimland
2,330
10,097
A Woosh bang
probably just a loose hose connection.
glad it was a simple fix.. (y)
pops
544
697
south glos
Pilote panel van
since1997
Toilet roll holder could be held on by a small grub screw on each end at the bottom. Undo screw, pull lower end towards you gently and lift upwards off of brackets.
Rooky Vanner
Mar 23, 2015
93
122
Since 1989
OK the moment you have been waiting for.....Elddis 140 (08)
RESULTS
Sink unit came off with three screws, 3 leaks, Waste had come off, pipe had come off warm tap, tail was pushed slightly out of warm tap, seals in tap leaking. Is that four?
Removed sink and pushed pipe back on refitted, leaked
Pushed tail back in warm tap, refitted, leaked
Reconnected waste, refitted, leaked, small whiskey!
Took tap out again! options...Fit new tap? £65.00, Dismantle tap? (Reich) maybe?
Dismantled tap! nothing to loose! Gungho!!
Found seals leaking on tap body! Can't get new seals, dont exist New tap?
NOO!!!... Tight yorkshire man!
Too 'O' rings of correct size,
Re assemble tap refit....wait for it????
NO LEAKS....LARGE whiskey!? or two<>?
Thonks ti alle whe heeelpeed!?!?
Rooky Vanner
Mar 23, 2015
93
122
Since 1989
Refit cupboared door knob that fell off, refit warm air pipe rear cupboard, down side, colder boots? Sort engine management light, (nothing serious) and look out here we come!!! You will know us if you see us, were the ones with a dry snug van dry socks and no wellies!!
calion
406
527
C class
since 2008
You certainly deserved that whiskey! Well done, I'd have been swearing by now!
Oct 7, 2013
5,894
36,913
South Wales
Swift Escape Compact
Since 1988
Enjoyed reading about your progress
Hopefully, all will be well now.
Good luck!(y)
Rooky Vanner
Mar 23, 2015
93
122
Since 1989
Guess what... Van Battery flat!! STILL SMILING!! Wife now on pushbike at the rear to charge battery... ha ha
Scout
3,959
121,302
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
could be worse, bike could have a flat or buckeds wheel, no power from that
wingman
1,217
3,333
Romford, Essex
Coachbuilt Lo-Profile
Since 2012
@Rooky Vanner You should change your name to Percy-Verance!
Well done you. I remember reading your first post and thinking, "Poor sod!"
Not ONLY have you fixed it all, but with humour and keeping us entertained too. You've also given us the final outcome, which is more than some do!
Happy (dry) travels and tell that missus of yours to pedal harder :D
Rooky Vanner
Mar 23, 2015
93
122
Since 1989
Ha Ha many thanks...Next trip today late PM, Battery sorted well pedaled twife!! and were off!! Brace yourself for the next installment. Don't know what I did with my time pre mo mo?? no time for holidays now!!
