Water returning back up drain. Is this normal? (2 Viewers)
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
2018, Apache 634 150 Auto
Hi Folks,
Ref: Autotrail Imala 615
When draining water from the kitchen sink I am finding that some of the drained water is being forced back up through the shower drain. I think I understand the principle but is it normal or is there a problem?
Cheers,
Steve
RowleyBirkinQC
2,348
227,120
Dazed & Confused
I was wondering the same, test having emptied to verify, don't rely on the waste water tank gauge alone.
Nov 6, 2013
3,201
229,736
East Sussex
Hymer B574DL
Since 2011 (tugger for 20 before that)
Defiantly not normal in my experience.
I think you have a plumbing issue or, as others have said, tank is full.
Is It new? If so let the dealer sort it. (y)
Jim
Ringleader
Jul 19, 2007
36,446
131,004
Sutton on Sea, UK
Adria Panel Van.
Since 1988
As your waste tank fills right to the top, your shower tray being lower than your sink and wash basin will gurgle and eventually fill. :D If what you describe happens with an empty tank then it does need investigating.
laneside
Aug 14, 2009
2,668
6,276
Oradour sur Vayres
Rapido V66
nowhere near long enough
Now this does not surprise me as we had a new Bailey caravan that did just the same, it was however easy to investigate on a caravan as all the pipes were exposed underneath. Bailey appear to live under the idea that water can run up hill.
The answer is no it is not normal and does need investigating
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
OK guys thanks for the replies. Waste tank fully drained and happened the first time the sink was emptied so it appears I have a problem. Will report to dealer. Cheers, Steve
Feb 16, 2013
19,738
52,048
uttoxeter
ambulance conversion
50 years
Was you level, ours sometimes does it if we are rear up, as the pipes join somewhere and they can't drain to the tank at the back
jonandshell
5,476
8,299
Not got one!
Is your van the right way up?
Drains rely on gravity. If you park your van on its roof, you will always get grey water coming back out of your drains!:)
Dec 12, 2010
5,414
21,593
Cumbria
Does the shower drain ok when you use it ? Does the regurgitated water that appears in the shower eventually drain away ? If it does, it's probably trapping air in the system, just leave the plug in the shower when you empty the sink.
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Yip, used a bubble, it told me I was fine.(y)
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Haven't used the shower yet but I can try filling the tray to see what happens. It is not a big deal but I just don't want excess water going where it shouldn't be if you know what I mean.
ABZSteve
ABZSteve
Banned
Jan 8, 2014
1,524
1,658
Aberdeen
Are you here or in the southern hemisphere? I hear that British MoHo's are not designed for the anticlockwise drain gurgle of those far away places...:giggler:
Well that shouldn't be a problem because I fitted an automatic water reverse-rotation device for such instances. Got it on the same shelf as the left handed screwdriver, elbow grease and Tartan paint(y)
Dec 12, 2010
5,414
21,593
Cumbria
.....also we always travel with the plugs fitted in the sinks and shower, as even though they're fitted with miniature U bends, you can still get the heady waft of your waste tank percolating through the van.
Feb 24, 2013
13,087
101,483
Bolsover, Derbyshire
Hymer S800
not long enough
same as jockaneezer, the only time we remove our shower plugs (we have 2) is to use the shower, then when tray is dry we push back down. That might just solve your problem (y)
O
Old Soldier
12v or gas? Oh, and I found the stripes ran in the paint... :happy:
Feb 5, 2009
678
783
South Essex
15 in MH, 15 in Caravan
I had the same issue with my panel van where I found the sink & shower drain pipes were T-eed together under the van just before entry to the waste tank. The solution was to remove the T and run them separately into the tank...
