Scout
- Apr 4, 2009
- 3,960
- 122,270
- chic c line
- 12 years motorhoming, a lifetime of living
Last week my water pump stopped working, it would “hunt” with no water coming out of the taps or “run on” after the taps were closed. I had a look and felt drips coming from the pump head main body. As we were touring in the lakes I dropped into a local service company who had a pump in stock and fitted it for me. All seems well the pump is working 100% ok but on getting home I noticed the new pump (a shurflo) is rated with a pressure switch of 45psi whilst the old pump was only 20psi (it was a posiflo make). As everything seems to working ok should I concerned at the different psi rating?
Looking at the old pump there is scaling or staining coming from 3 or more places between the main joint. I presume air has been getting in here and causing the problem, is it worth reconditioning this pump? Is it just a clean out and make a new seal job or is them more to it. I noticed new heads are not much cheaper than a new pump.
