Bonglewagon
Hi all,
I have a Globecar Roadscout R. If I turn on a tap I may get some water for a few seconds and then a high pitched whine develops and the water supply ceases. Or I get no water, just the whine.
It is possible that I may have damaged the pump when showering. The Roadscout shower has a control on top of the shower head in addition to the main tap over the bathroom washbasin (which activates the pump). To shower you turn on the basin tap and then use the control on the shower head. After showering you must make sure you turn off the basin tap to shut down the pump. I forgot to do this and was only alerted to the problem when an ever increasing high pitched whine developed (the pump was trying to pump but could not expel water as the shower head control was shut). The next day the pump fuse was blown (and I replaced it).
So now the pump may work briefly (or not at all) before I get a high pitched whine and no water.
My questions are:
1. Has any one had a similar experience? And if so how did they fix it?
2. Where is the water pump on the Globecar Roadscout?
Any advice much appreciated.
My questions are:
