Water Pump Adjustment.... (1 Viewer)
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Is there anyway of adjusting a "Sureflow" water pump... ?
I have noticed over the last few days it purges a lot more than it did...
Still pumps hot and cold OK but it`s like turning the tap on and off quickly...
It`s in an awkward place to get too.... :Sad:
Easy laymans terms please if it can be done... :Doh:::bigsmile:
Mel
2,131
2,810
De Haan Belgium
Caravan LMC
Since 2010 Caravan since 1995
Yes it can but i dont know how.
Also it does that in Spain and stoppped when I was at Park Verger.I just thought it was air in the system but dont know for sure.
Mel
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Mel
Thanks, Mel... :thumb:
I`ll leave it for now...
It has always done it a little,,,,, but since coming here it is getting worse..
Spose it could be the crap desalinated water,,,, Always descaling the kettle... :Sad:
Hate to think what the boiler`s inside is like... :Blush:
icantremember
8,333
17,545
Near to Watton in Norfolk
Hymer T-SL668
since 2005
I'm sure there is an adjustment screw on one end of the pump, however we had a similar problem and solved it by fitting a Fiamma A20 accumulator.
Fiamma Water Expansion Tank Acumalator A20
The Fiamma Water Expansion Tank Acumalator A20 eliminates the pulsating operation of the water pump and allows a flow of constant water at the required quantity.
It will assist in lowering the water consumption and will extend the life of both the pump and the water boiler (pre charged at 0.9 bar - 13.05 PSI)
http://www.johnscross.co.uk/products/fiamma-water-expansion-tank-acumalator-a20.html
old-mo
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
:thumb::thumb: Thanks...
I`ll put that on the list of to do things when we get back... :thumb:
TerryL
6,187
8,189
North East
Low Profile
Funnily enough our water pump has started being a bit touchy, even though we've got one of those accumulator things. It's on my list of jobs to do today (well alright it's the ONLY thing on my list!) so if I find anything I'll come back and let you know.
Terry
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
Terry
Yes, but once a year, you are supposed to 'purge' the accumulator. This is done, (depending on type), by letting all the water out of the system, and then opening the top valve of the accumulator tank, which allows any water inside to run off, thereby 'replenishing' the air buffer required. Tighten up the valve after a few mins, then re-fill the water system.
Over a period of time, the water level increases due to small air loss from the tank. This reduces the pressurising effect of the air against the water, which then lets the pump run more often.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
I will do it for you at Zahora.
Sometimes they hide the adjusting screw behind a label.
Mine is a tiny Allen screw... I have the necessary key.
JJ. :Cool:
In our workshops this time of year wlilst carrying out habitational services we see alot of cracked particle filters (on the inlet side of the pump) which will give you the symptems you are experiencing.
The filters are around £15.00 and in stock!!
Regards
Glenn
TerryL
6,187
8,189
North East
Low Profile
:thumb:Thanks for that - of course I'd put everything back in the locker when I got your reply:cry:
I'll leave it for now until I need to make some room again for "stores" for Morocco.
Terry
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
To Glen at Johns Croos
Would that give the symptom of a noisy "tapping sound" when using the pump ???
Mitch.
RandallC
1,242
3,487
Devizes
A Class Rapido 8096
2012, prior too, 17 years Folding Camper & Caravan
Hi. Have a look at this info from the swift site
Link Removed
43,330
49,446
the screw on the end of the pump is to set the electrical 'cut off' point.
if the pump regularly pulses you have a leak somewhere.
it could simply be the valves in the pump are a bit weak, or a spec of grit under the seat, and allowing water, thus pressure, to feed back into the low pressure side of the valves.
the diaphragm could be slightly porous or a minor pinhole
pipework could have a minor leak.
adjusting the screw will only make the pulse a bit less regular but may pump for longer to build back up to the higher cut off point.
if adjusted too far the pump may not produce enough pressure to activate the cut off micro switch and the pump will continue to run, under load, indefinatly
actual water pressure is factory set by cylinder and valve size and design and is not adjustable.
i had to fully dismantle my pump and i understand the inner workings of the 3 chamber diaphragm pump
TheBig1
17,630
43,280
have seen similar symptoms on pumps where the diaphragm is slightly perished and weak or covered in limescale. check for a crack in the strainer and if youve got a service kit, refurb the pump. should then be good as new
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Mitch.
Over the years, we have had four of these pumps on our narrowboat. They all failed due to the glue which holds the permanent magnets onto the inside of the armature case perishing, allowing the spinning armature to hit them. This causes the magnets to eventually smash into a couple of pieces. You first hear it as a ticking noise.
So I bought a Jabsco diaphragm pomp. Much better, and a hell of a lot quieter. It has 5 diaphragm chambers instead of the normal 3, is cheaper, and has now lasted us 6 years.
http://www.jabscoshop.com/marine/pumps/bilge-pumps/dc-diaphragm-pumps/
