Water Problem . (1 Viewer)
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Can anybody shed any light on why I'm loosing so much water while on the move ?
I have a Elddis sunstyle 140 on a 08 plate.
On Thursday I set off from home with a full tank of fresh water by the time I reached Dover (220 miles) I was down to less than 1/2 tank.
This is going to cause me problems as we plan on doing lots of wild camping.
Any thoughts/ideas much appreciated
scotjimland
2,327
10,094
A Woosh bang
You have a leak .... have you looked underneath after filling up ?
Either that or it's sloshing over the overfill..
all I can think of, someone with your van may be more helpful
mjltigger
1,619
2,672
Trowbridge
Autotrail Dakota Max
I know some of the tanks have an overflow that is always open and driving can make it slosh out but would be surprised if that accounts for losing half a tank.. unless you are taking it very rough.. are you sure it's actually full not just reading full.. might be a sticky float sensor (if that's the type of sensor yours has) which frees up as you drive.. of course there is a chance you have a leak in the side of the tank about 1/2 way up but I would have thought you would spot the wet patch when you stop..
oh another thought.. are you running heating and hot water as you drive and did you drain down before you started.. might be pushing a load of water from your fresh tank to your hot tank..
and of course, could be a combination of multiple factors such as some of those above or some I didn't think of..
eddie
8,157
41,270
Taunton Somerset
RV
since 1989
Probably the water is being syphoned out of the overflow pipe. When driving the wind passing across the open bottom of the pipe creates a partial vacuum (called the venturi effect (I think if I remember my schooldays lol) the water is pulled into the pipe to fill the vacuum and "Hey Presto The case of the disappearing water!
Try to shield the overflow pipe or re-route it to a more sheltered position will improve things or cure the problem
TheBig1
17,630
43,279
or the automatic dump valve is operating
could also be siphoning out of the relief vent
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Definitely not leaking as I can fill it up on my drive, pull water through taps & heating etc
And there is no wet patch under the van
Jim
Ringleader
Jul 19, 2007
36,421
130,921
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I had an RV that would siphon 3/4 of a tank of water on route. Had to fit a tap on the overflow in the end. But, the most common cause is that your water heater dump valve is operating.
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
we had a problem that took some finding, the fill pipe had a split in it quite close to the external fill point, when driving the sloshing up and down the tube emptied quite a lot of what I had put in, not half a tank though. Our sign was a bit of wet on garage floor, but it is well drained and never seemed to be wet enough to worry about.
Changed when I bought a filler adaptor so we have a cap with hozelock connection, I was filling and was also doing something in garage as I now had spare hands, noticed water cascading through the garage when tank was full
our water tank is the opposite side to the fill point, about a metre of filling hose all hidden behind panelling in the garage, but sorted quite easily
Lenny HB
53,431
150,019
On the coast in West Sussex
Hymer B678 DL
I think Elddis fit a caravan type tank with an overflow, easy fix, fit a short length of hose to the overflow with an inline tap. turn the tap off when traveling, need to open for use to allow air into tank as water is drawn off.
JeanLuc
3,304
2,199
Warwickshire
Hymer B630 Star-Line
I would suspect that the Truma frost protection valve is activating whilst you are on the move. This happened to me a couple of times before I realised what was happening so I made a clip to keep it closed.
At this time of year I clip mine closed whilst travelling (but remember to remove the clip as soon as you arrive and have got the van warm).
Lenny HB
53,431
150,019
Hymer B678 DL
Don't think so, the problem OP described is a common problem with Elddis vans, if it was the dump valve, it would be peeing out when he filled the tank not just when traveling.
JeanLuc
3,304
2,199
Warwickshire
OK obviously different to my experience but then I have never had anything to do with an Eldiss. I can fill the water tank with the Truma dump-valve open (no leaks below) and the tank only empties with the 'sloshing about' caused by travelling.
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
on a dry day ,so not in the foreseeable future , fill tank run around the block then look under neath and check for wet if its an overflow pipe maybe you can extend it higher with flexible hose
Lenny HB
53,431
150,019
Hymer B678 DL
Think it depends on the height of the tank if it syphons out or not.
Edit:
Thinking about it the hot tank would need to be full for it to happen.
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
Thanks for the reply's i think i will start with the overflow on the tank first.
Had a quick look tonight,it just looks like a molded plastic outlet on the top of the tank around 20mm.
So i'm going to attach a length of flexi to it with a tap on the other end.
TheBig1
17,630
43,279
if its just a bare fitting on the top of the tank, then the vent pipe has fallen off or was not fitted at the factory
RS SPIKE
RS SPIKE
192
29
derbyshire
ELDDIS SUNSTYLE 140
newbie
P
if its just a bare fitting on the top of the tank, then the vent pipe has fallen off or was not fitted at the factory[/QUOTE
Do you have a picture??
Would that be a pipe with some kind of valve in it ???
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
As the inlet to the overflow is above the water level in the tank it cannot syphon. It is conceivable that an unnoticeably small amount could find its way out as the water sloshed about. Fitting any sort of tap to the overflow may cause other problems like a pressurised tank on hot days or a collapsed tank if you forget to open it.
