Water Gauges on Miami (1 Viewer)
silverlocks
19
24
Gosport
C class
20 years
I cannot seem to get a reading on my water tank display, it always says 0%, any ideas where I should be looking.
Bob
Wildman
8,470
Ilfracombe, Devon
Amazon Ambassador
since 1967
best place is the tap if water comes out you have some is not you need to refill.
Tank gauges seldom work for long in any model of van.
silverlocks
silverlocks
19
24
Gosport
C class
20 years
then in my opinion you shouldnt reply to anymore technical queries as you obviously dont know much
43,329
49,446
Wildman is right Bob.
Unusual to constantly register empty but it can happen.
If you have room around the tank look for the sensor wires....they may have come adrift.
It wont be very accurate when it is working and can lull you into believing you have plenty of water when in fact you are about to run out.
The grey waste is even worse.
all the muck, food particals and soap scum which goes down the plughole can clog up the sensor
indicating a full or almost full tank when it could be almost empty.
So, as Roger said...if water come out you have water and if water comes back up the shower plughole your waste tank is full.
K9Brian
605
575
South Manchester
Since April 2010
You might not like the reply but I'm afraid it's true. Most sensors play up before long - had mine fixed twice in 2 years.
43,329
49,446
Sorry Bob, but being a member for the last 6 years you should know you are going to get some useful replies, some not so useful and some sarcastic ones.
Roger was not trying to be funny....just giving an honest answer in his own way.
JockandRita
11,462
150,160
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
That's really helpful Roger. Lol
BTW, our 15 year old gauge hasn't malfunctioned during the 10 years of MH ownership, :)
Bob, you need to check the fuse for that circuit. If it's not blown, check the connections are secure,and if you have access to a volt meter, you can check for continuity in the circuit.
HTH,
Jock.
pvw10
273
45
Gloucester
Coach built
since 2011 after tugging.
I think if you can't answer somebody properly and clearly who is asking for help then don't bother, sarcasm sucks. If the reply was intended to be a genuine reply then improve your English.
My Miami continues to give good readings but as rightly advised not accurate, I just use as a guide.
K9Brian
605
575
South Manchester
Since April 2010
A great pity you bothered with the first paragraph at all. The second paragraph was all that was needed.
pvw10
273
45
Gloucester
Coach built
No it's a great pity people leave cryptic notes instead of helping somebody that asked for help, and was quite rightly upset
RowleyBirkinQC
2,347
226,858
Dazed & Confused
But in the most basic form, surely the tap working or not is the ultimate indicator of whether you have water onboard? I didn't read that as overly sarcastic, nor would have taken offence, was the main point not that the water gauges are notoriously inaccurate/unreliable?
Anyway, we bought a 2006 Tracker a few months ago and the water level reading consistently read 0%. We took it back to dealer who fitted a new sensor under warranty to fix it. They also mirrored the same sentiment as to the reliability of such.
Lenny HB
53,431
150,016
On the coast in West Sussex
Hymer B678 DL
If the sensor in the tank is the type with 4 probes a build up of calcium from hard water could be the problem, take the sensor out and de-scale it & hopefully it will work. If it is a new van could just be a faulty probe, our last Hymer the probe failed when it was only a couple of months old.
If it's not easy to get the probe out de-scale the tank, I always use white wine vinegar for de scaling it works best hot. Truma used to recommend white wine vinegar for de-scaling their boilers until they brought out their own product. We always stock up on it in France about €0.30 Lt.
f6c
Nov 7, 2010
10,960
4,793
gloucestershire
Carthago Malibu 640
23 Years
Wildman is right I have a Auto-trail 05 plate tank gauges rubbish never worked properly even when new accurate.
pvw10
273
45
Gloucester
Coach built
On water mine is good to about 50% then sits there then suddenly drops.
On waste it is accurate and reliable but as lennyhb states a good yearly soak with white vinegar I'm sure has kept it this way as was getting worse "pre vinegar".
