Water filter
Discussion in 'Tech/Mech General' started by RogerD, Aug 16, 2007.
  1. RogerD
    RogerD Deleted User
    Can anyone reccomend a Water filter that is easily installed in my Bessacarr E495, I have done a search and there seem to be lots of different ones, does anyone have any reccomendations for something that is cheap and easy to fit but still does the job. I don´t want to be tied into buying really expensive filter replacements, is there any other way?
  2. 656
    656 Read Only Funster
    Jul 30, 2007
    1,150
    291
    The universe
    Try SCREWFIX Cheap and easy to fix and cheap cartridges - £2.99. They are far cheaper to buy and run than NATURE PURE Cartridges for these are about £45. Mind you the Nature Pure is about 1000 times better but may be overkill for use in this country. If I had room I would have Nature Pure.
    Dave
    656
  3. fordy
    fordy Deleted User
    Hi i just fitted a water filter and tap got it from eBay Item number: 230154822319
    very easy to fit took 15 minutes runs fine with the water pump in the RV i fitted it to the plastic hose in the RV simple cut in stopcock very happy with it ..And the tap is a good quality one not one of the plastic cheap ones
    FORDY:Smile:
  4. woodyold
    woodyold Read Only Funster
    Aug 20, 2007
    114
    Poole
    I use nature pure , easy to fit , mind you most of them are im told , the water always tastes good even when its been in the tank for weeks let alone days , i know the cartridges are expensive but if your using it like i do at weekends bank holls , and 5 weeks holls a year, ive found the water tastes good up to 2 years .
  5. camcondor
    camcondor Read Only Funster
    Jul 27, 2007
    1,044
    478
    East Midlands
    Is it a good idea to completely drain the tanks (fresh and waste) now and then and how often should one do this? Also, is it a good idea to disinfect both tanks say once a year and what is recommended for this? Milton / Fairy / bleach 10% ??
    We never use the water for drinking, just sanitation / washing etc, but with a filter attached perhaps would consider it. Where is it best placed or does this depend on the vans layout?
    :Confused:
    Laurie
  6. woodyold
    Aug 20, 2007
    114
    Poole
    The water filter usually fits via your existing cold water pipe under the sink , the faucet fits on the worktop usually next to your tap , youll see the set up if you go to the nature pure website ........ If im on a site with fresh water tap i fill up the tank and use a milk bottle for the kettle but i always use the filtered water if theres no tap around , on a lot of ralley fields theres either no tap or its too far and cant be bothered to keep walking to it . I tend to drain the fresh water tank if im not using the van for a while , Ive never used anything in the fresh water tank such as milton etc i just empty it when im not going to use it for a while and leave the drain cock open to let it breath , it works for me . The waste tank i empty when possible and again i leave it with the drain cock open when the vans not in use .Ive not had any bad smells yet [ touch wood ] .
