Waste valve (4 Viewers)
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
I'm rubbish when it comes to pipe threads / sizes so i need help!!!!!!!!!!!!
I need a new Valve / turn tap to go onto the end of my grey waste water pipe , but i don't want to order the wrong thing online so i thought i would ask :)
Below are pictures of the pipe , both ends are threaded the same ,, one side to grey tank , the other i need a new valve / turn tap for it :)
Jun 11, 2011
376
435
Somerset
hymer s820
hya its a 1" one you want the size is on the collar but as dbk says take plumbing shop to be sure
Reactions: DBK
18,035
48,145
Take it Plumb Center or similar, they should be able to find something to fit it.
17,635
43,369
cheapest source I have found for 1 inch bore and above plastic waste fittings is a pond shop
bluebob
101
168
West Lothian
Knaus 650 MEG
Since July 2013, moved from towing caravans
Bart, maybe you shouldn't worry about a new valve as I believe these are normally left open anyway.......;)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
See the 1 inch part is where I got lost .. as it's 32mm pipe . So where does the 1 inch come onto it.. is that the thread?
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Just been to my local garden centre that does pond stuff.. they had nothing that did it..
Back to looking online
17,635
43,369
@TheBig1-shurely you mean the Pound shop?:)
If you can find a 1 inch gatevalve in a pound shop, you go for it. My local pond and aquarium specialist shop stock all manner of large bore water pipes cheap, but nowhere near a quid each. About quarter the cost of going to a motorhome spares company because its not being sold for a leisure vehicle
Feb 22, 2016
3,620
10,752
York
Bailey 620 Approach
Sorry; I was being flippant. I realised you meant a shop that sells pond perquisites. I'll close the door on the way out.....
17,635
43,369
or this will just screw on may need a bit of ptfe tape to make the joint up
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Thanks man , i already have 1 of the brass ones , but my problem is that it is male and the plastic pipe end is male , so i was not sure what connector to buy to use it , also though while i was there i would be best changing the valve to plastic , same as original ?
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
if i got this :
would i then be able to use that to connect the male end of the plastic pipe together with my brass MALE ended valve that i already have ?
Badknee
7,408
413,037
notloB
Vantage Neo
Living the dream.
Another problem I encountered was that the 32mm bore went down quite a lot to about 18/20mm which is useless. Another place to try is a swimming pool installers/supplier. The pipe work in the plant rooms is quite large bore.
17,635
43,369
if i got this :
yes that would work, but again you will need to make the joint up with ptfe tape
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
I notice you have a Bessacarr.
Is This what you need? Remove the straight plastic piece and screw the valve onto your pipe?
That looks like the job , but its expensive enough :D i have a 1" screw gates valve i might try that 1st to see if i can get used to that valve,, if not then ill order the lever valve you linked
Thank you! :)
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
went down to my local plumbers merchant just before 4pm and took both the male ended valve and the male ended pipe ,, and he said there was nothing that you could get to connect them together,,
Yet my 1" gates screw valve with the female end screws ok onto the male end on the grey waste pipe ^^ ..... so thats what im gonna try now, ut id rather use my lever valve
Nov 5, 2013
3,105
97,895
Shropshire
Carthago chic e-line
any agricultural suppliers in your area? Quite common in wet feed and irregation systems.
Dec 12, 2010
5,415
21,601
Cumbria
The threaded plastic end with the hexagon on it looks as if it will unscrew from the end of the fitting marked KIWA on your first photo, allowing you to screw your male threaded valve into it.
The call it a 1" fitting because the bore will be nominally one inch diameter.
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
i tries that in a vice , it looks like its the glued in type
Bart
Bart
3,188
1,398
Northern Ireland
Since 2016
Does this one have the correct internal female thread , its listed as 1" , does that mean the female fitting is 1" or that the actual valve chamber is 1"
Select the 1" size
Nov 5, 2013
3,105
97,895
Shropshire
I'm pretty sure the size will be the thread size,....postage is a bit steep!
must be someone your side of the water who does something similar,these people are in Dudley.
Dec 12, 2010
5,415
21,601
Cumbria
Select the 1" size
Looks like it will do the job (y)
