Warranty Issue (2 Viewers)
duane0001
792
778
East Coast, North Yorks
Expedition 67 soon!
2021 This time
Well my onboard charger seems to have fried itself and seen as the van is under warranty it is going in for this job on Tuesday.
What I want to know is what I should be expecting under warranty
The charger must have shorted somewhere because it discharges my leisure battery in under an hour which has damaged the battery and wont hold a charge anymore, can I expect a new battery as part of this warranty job?
Also the spring in one of the window blinds has gone, can I expect this under warranty?
I have had the van 6 months and got a years warranty on it
Duane
43,330
49,483
if its discharging an (assumed) 110ah battery in an hour i would be worried....very worried....as whatever is causing the drain is pulling 110 amps
that is one hell of a big load and i'm surprised there hasnt been a fire.
have you checked the chargers output voltage as i would suspect a shorted/dead cell or two in the battery more than the charger.
could of course just be a completely knackered battery.
Daveo2006
1,164
998
kent
Apache 700
3 years
Duane
Was the leisure battery new also? if so it would be covered .It should also be covered with dealer if sold with the van i would have thought?Would a dodgy battery damage the charger?
duane0001
duane0001
792
778
Expedition 67 soon!
2021 This time
85 amps and not a new battery when van was purchased
I am not after tech advice, (I can do all my own work)
Its what I can expect under warranty
Cheers
43,330
49,483
you can expect all you want..but what you'll get is a different thing.
they'll either blame the charger for the dead battery or visa versa.
in my experience aftermarket/in house warranties arent worth the paper they're written on
Daveo2006
1,164
998
kent
Apache 700
3 years
Cheers
Read through your warranty as new buy warranties cover everything ,not sure on used.However as a gesture and to restore faith i would have thought all would be replaced.I pretty sure they will claim on their insurance.
The leisure battery supplied with my van was a dud,it was new and showed green on the battery itself and also would show full on my control unit for a short time and as you say discharged an hour or so later.I made sure i checked everything was off and even turned vehicle battery off at ignition just incase that was knicking the power.Was defo a naff battery ,probably where potential buyers left led's and things on.
