warning light (1 Viewer)
smiffy502000
249
124
sutton coldfield
coach built.
since 2008
hi all.can anyone help? just had great long weekend away.but just driving back home the emmision warning light came on.its a peugeot boxer 2007.only done 15000 miles. should i panic yet? can anyone give us a clew as to what it may be:Sad:
rainbow chasers
3,680
1,725
Mid Cornwall
Various
Either a faulty sensor on the injector rail, or the short injector loom problem. Just to check the injector loom and ensure all is connected correctly.
Dec 6, 2011
11,593
25,425
South Wales
Coach built Adria
a snipped post of info i picked up
Quote ( Same warning light came on several times so I phoned Peugeot Assist.
They said if vehicle also had a loss of power then seek immediate assistance. If no loss of power at all it is likely to be a sensor problem and expect it to go off after either a few miles or after a few starts of the engine!!! )
apparently this info was from Peugeot
Jul 28, 2010
1,710
617
The world
Small car
Take it to a garage and they can test it
No one on here can really tell you what he fault or the warning is exactly as
Modern motors are chip computer aided. So you need the punter program to read the fault
Yep it's a way to get money out of you
So yes panic. The bank account will take a hit :ROFLMAO:
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
Find out how to get the code readout and then post it somewhere that understands Peugeot engines. On my Vauxhall, which has the same Fiat engine that is in plenty of Boxers, you hold down the brake and accelerator firmly whilst turning the ignition (not starter) on. Then the mileage readout comes out with the error codes. Peugeots could be identical to this or completely different, but I bet there is a similar trick if they're different.
greyman1
374
279
manchester
9 years motorhome / 10 years campervan
if i remember rightly, this light can also be triggered by a issue with the vehicles particulate filter . you would need to check which system is fitted as to what action is required . regards garry
Apr 9, 2013
663
373
Ayr
Newbie
2007? I doubt very much that it will have a DPF.
Dec 6, 2011
11,593
25,425
South Wales
Coach built Adria
the light is related to particulate filter but only on Euro 5 engines which were not released in uk prior to late 2011.
cmcardle75
2,666
3,446
Reading
Riot Van Conversion
Since 2012
My 2008 has a DPF.
