Billynixon
Hello, I'm looking for a motorhome preferable coach built and nothing too dated. Have around £5,000 to spend. Is there anything out there? Thanks.
For that kind of price range it will probably be quite old, (unless you are very lucky) so budget for replacing things that deteriorate with age and mileage and have a tame mechanic on hand (yourself?) or a good warranty !!! 5K does not go too far in the MH world I found this oneHello, I'm looking for a motorhome preferable coach built and nothing too dated. Have around £5,000 to spend. Is there anything out there? Thanks.
That is a big ask;
Broken Link Removed
12 months MOT Habitation check etc??
1987 27 years old this has done the test of time brilliant on fuel average 47 to the gallon
Well spotted, but they did not actually state 47 what to the gallon.Hmmmm.. That all looks good until you get to the MPG..
Yessssssss... with such an obvious and nutty fib it may be worth taking the rest of the info with a pinch of salt !
But.. well worth a look !!!!!
There is another nugget in there:
'we recently papered the inside to our taste'
That may well be true, but its also often done after damp repairs or to hide damp.
Now ya talking! With careful shopping a 1995 (ish) Hymer that has had an easy life could well be with in your reach. As older vans go the Hymers are definitely the ones to go for, especially If you don't mind left hand drive.Thank you everyone. I will take all into consideration. Yes I have noticed a lot of scams around on eBay and probably other sites however the only way I will do a transaction is cash only so I should be ok. Hopefully in the next month or 2 the budget should go up to around 9-10 thousand so hopefully more doable.
