Wanted. 100w solar panel (1 Viewer)
23,836
72,549
Before I chuck a load of wonga at a firm, anyone got a 100 w panel up for grabs ?
Must be mono not polycrystal...
23,836
72,549
Quick bump and if no one has one by tomorrow I will grab one off of fleabay ..
With the 290 aH of battery I know have I reckon a minimum of 300w worth of solar panels is needed to get the best from them ( and yes, we are heavy elekrickery users ! )
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
300watts of solar will be a great bank of panels.. Remember when looking a decent MPPT regulator (Victron make a good one(y)) will make all the difference. A individual regulator per panel will give the most efficiency back..
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I don't think I'll be fitting three regulators :ROFLMAO:
JimJams
249
377
East Sussex / Kent
RV, A Class
since 2003
looks good(y)(y)..
The only main reason why I would install 3 regulators is simply because there will be no risk of your panels not charging when a certain amount of the panels are possibly shaded..
Techno
Jul 28, 2010
15,475
20,756
May 2010
If I cover one panel I still have 200 watt working. I find shade on one panel affects that panel not all three
Techno
Jul 28, 2010
15,475
20,756
May 2010
They also do a 200 watt unit at a bit less wonga but you will get about £16 import charges from parcelfarce with either.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I always check the contents of regulators. You'd be surprised how little there is in many despite a nice looking outer skin :LOL:
In comparison a 300 watt pwm regulator
19,377
30,373
If you use a Votronic MPPT regulator/controller it will run your AES Fridge for you on 12volts, especially with 300 watts of solar and a good battery bank you should get a good few hours a day.
You can also plug a Votronic solar computer straight into the controller and it will log your power genation, we have had about 15000 ah in the two years since I fitted the new panels and Votronic bits.
23,836
72,549
I bought a very posh ( read bloody expensive at £200 plus ! ) controller last year.. Digital scolling read out of :
Battery type ( auto detects )
Current voltage
Current current ( drawn and or going in )
Plus some other stuff which I cannot remember off the top of my head.
The only downside is the language used is in Spanish.. Or one or two other really obscure choices !!
But as numbers are universal and are the important things, that is not really much of an issue :)
23,836
72,549
You could try bimblesolar.com they have used 120watt 12volt panels for £55.00 (bank transfer) plus carriage.
Just had a look and they are Poly panels, not mono ones..
Always cheaper, but that said they do seem to be very well priced indeed Link Removed
Oct 1, 2013
7,513
19,954
Lanzarote
Nil by mouth
Lots
What's the difference between poly and mono?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
in use not alot . i still use a pwm reg they work are cheap and why spend a fortune if you dont have to.
first i had mono then the second lot were poly . never noticed any difference . now i have 6 indian made bp 80wt panels . pwm reg and have enough power all winter abroad.
think many spend far more than they need to.
i use a 24v to 12v battery to battery charger by durite when on the move . bought that about 8 yrs ago .
Broken Link Removed if i was buying today these look ok.
but not mono.
23,836
72,549
LOL !! And that is precisely what I ordered about an hour ago !!!
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
its just a pos to pos then pos to regulator same on the neg . some come with fancy connectors we use junction boxes . you might need a gland nut fixing through the van . http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xgland nuts &_nkw=gland nuts &_sacat=0
similar to this . this is for viewing only .
i use a reg like this one .
again pos to pos reg to battery ,same the neg .
some put fuses in line . i havent bothered .
i,m sure if you speak to a supplier they can send you what you need .
