VSR's (1 Viewer)
darklord
1,241
1,230
essex
coachbuilt
three years
http://continuouswave.com/ubb/Forum6/HTML/000612.html
I fitted one of these to a battery needed for winching, just some info for anyone not familiar.
I am currently doing the sums and research on what "extra" power i am going to add next time. it won't be solar,........it might be a genny, it might be an uprated alternator, i doubt it will be a fuel cell (expense), but if I isolate it from the original set up, it will definatley incorporate one or two of these.
43,329
49,444
Errr!!!! vanbitz battery master in reverse.....wired to cranking battery with leisure battery as secondary instead of, conventionally, the opposite way
darklord
darklord
1,241
1,230
essex
coachbuilt
three years
Errrr, VB battery master needs 240, this does,nt. Vb battery master works in the opposite direction to a vsr.........hardly the same is it:Doh:
TheBig1
17,630
43,277
battery master is a 12v VSR
43,329
49,444
Read vanbitz own description of their battery master......it doesnt need 230v hookup...any charging source will work.
simply wired to the engine battery, instead of the leisure battery, it will work exactly the same way, once the engine is running and the alternator is charging the engine battery.
it doesnt know where the power source is coming from or where its going....it just knows that its connected to a primary battery.
Link Removed
