Votronic bluetooth monitoring. (1 Viewer)
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
As per title, being a bit obsessed with what I can make off the solar I get tired out going up and down the steps to check inside when I think there is just a bit more sun ;)
So thank to Michael sallylillian for trialing this I made a small investment in a Votronic S-BC, it comes with two data leads and will combine the readings from up to two Votronic solar regulators if you have more than two there is another box of tricks that will combine even more, you can still use your existing solar computer as it just loops out of the S-BC box, I haven't got that plugged in as we have a Buttner "hall effect" solar pro display.
The data cables just plug in where the solar computer would have been and the solar computer would go in the spare sockets,
The app is in German at the moment but they do say that there is going to be an English version soon, it is quite self explanatory though 3 Amps because the batteries are full, battery voltage, Watts, and then a cumulative total in Wh and Ah, Tage is obviously days so you can go back 30 days.
The battery monitor is only if you have an existing Votronic battery monitor you can couple that in as well but it takes up one of the data slots.
Now just need to be somewhere sat in the sun beer in hand watching it (y)
Martin
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Hi Martin
Had you considered Victron?
Built in Bluetooth connectivity and fully programmable via their app (in English)
Good question Robert, I went for made in Germany over China or India or wherever, I have had Votronic before and can't fault them they have AES out for the fridge which I don't think Victron have and lastly I know a couple of people who have reliability issues with Victron so not for me ;), oh and a direct replacement for the Buttner that were fitted including the battery temperature probe, the Buttner would have been fine except that obviously buying an entry level van we only got the PP/PWM regulators:LOL:
Martin
R
Robert Clark
Martin
Didn’t realise that the Buttner controller had an S+ output
R
Robert Clark
Hi Martin
Looks like the solar controller charges the engine battery too?
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Hi Martin
Oh yes It's the real McCoy, these are the biggies at 430watts so if I fancy another couple of panels at any time I reckon I can add them into the junction box of the panel on the roof.
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Have you connected the fridge again Martin?
TBH Jon I am more inclined to run it on 240 from the inverter as the 240v element is 250w and the 12v one is only 170w, would need to alter 240v wiring a bit more though.
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Thats noted for next time we are at the same meet. You can charge the drone, video camera and 2 laptops for me. :rofl:
Went away with friends who are always running out of power but won't buy new batteries ;) I said "it's OK I will have spare" 70ah later we find that not only charging batteries and running van but he has the fridge on 240v, didn't make the same mistake last week when he was plugged in.
So yes Sandra you should be OK.
R
Robert Clark
Martin
Is running the fridge from the inverter a standard feature or would you need to wire that up yourself?
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Martin
It's prewired to hook up only so yes it would need rewiring ;) I did the Microwave as it was easy and it was more important, will live with it a while and see how we go, if we have more power than we know what to do with it might happen, might be an idea to let it all settle down incase there are any warranty claims that could be complicated.
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
I have an argument against wiring through the inverter. If you are using the inverter on a pretty much full time basis with or without EHU you have to manually switch to gas or 12vdc. I do however see the advantages, if your battery bank is large enough no hassle on the ferrys. Better cooling on the road. 6 of one half dozen the other. I know others who follow Martins process.
Switching the breaker from one circuit to the other is no big deal.
That said I have mine on AC2 out of the Victron so it benefits from UPS support when on EHU.
Jun 10, 2010
8,524
20,238
Shrewsbury (sometimes)
N&B Clou Liner MAN
I can imagine the conversation about a warranty claim - " ok mr funflair, if you could just indicate the parts of the car that you haven't altered.........."?
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
:LOL::giggle: I chucked an old duvet on the fibreglass panel between the dash and windscreen and on tickover it took 2db off the sound level, guess what's next?;)
sallylillian
3,944
5,014
Falmouth, Cornwall
Palace Liner 90LO
Interesting, please share your plan. My underfloor insulation made a huge difference and this winter I will do the whole area. But getting under the GRP panel as you suggest???
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
Two controllers in parallel running two panels each then all feeding 3 batteries through a centralised connection point.
Martin
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
That's the problem, I don't know how I am going to do it yet ;) current thinking is 15mm noisekiller foam and then lining carpet, not sticking anything to the original so it would all come off if needs be, if nothing else it will stop some of the thermal gain on the gloss black, of course it has to incorporate the windscreen vents which just pull out but the Alde vents are stuck down so they will stay and I will make some new ones in carbon fibre (keep the weight down):LOL:
I still have to have a good look underneath and see if there is anything I can fiddle with there(y)
M
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
I’ve got two solar panels, they work, but then I only need it for my hair curlers and only then if I’m going to a ‘do’ suits me as the hair straighteners draw too much power;)
Sep 28, 2015
2,019
2,615
Kingston upon Hull, East Yorkshire.
Hymer B544
2001 Caravans 2011 Motorhomes
Martin
How much? Where from? Can’t find one on Photonic Universe site, I want one!
We have an MPP350 with 300watts of panels with the solar display in a cupboard that’s award to get at.
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
But how much solar power does this unit consume and what do you do with the 3.4657 amp gain?
dabhand
4,307
23,936
Staffs
Concorde carver E35
Since 1993
Martin
Sounds like you could do with something to plug into your “Buttner” Martin:giggle: I think Freud would say you were fixated at the anal stage of development, but hey weren’t we all? A man must have his interests and something to watch whilst outside in the sun with a bottle of wine, mind you a few other things worth watching spring to mind....... like the full gauge on the cassette!:LOL:(y)
funflair
funflair
19,376
30,366
Guisborough
MORELO palace
since 2012
250 litre black tank (y) and if I fit supersense I can watch the levels as I sit outside with a bottle of wine watching the solar levels;) I will still need to manually watch the level of the red wine bottle.
M
