Volt meter (1 Viewer)
Just how can they do this at this price ? No idea of quality but it seems worth sticking one across the batteries maybe with a simple Push-On switch.
Feb 27, 2011
14,741
76,096
Saw these a couple of weeks ago and was really tempted.
I wonder if you could get a shunt and calibrate one of these meters to do amperage as well?
Feb 27, 2011
14,741
76,096
found one...
50Amp one here cheaper
Destination Unknown
398
835
Anywhere and everywhere
American A Class
Not Long Enough...!!
This is the type we have fitted to the rig. Volt meter via 3 way switch which shows volts from Chassis/Leisure/Leisure (spare)
Also fitted same design but amp meter via shunt, shows what we are using from leisure.
Again only a few quid each.
Jim
Ringleader
Jul 19, 2007
36,447
131,037
Sutton on Sea, UK
Adria Panel Van.
Since 1988
How they can make them, ship them 8000 miles, then the maker, seller and eBay still make money, it beggars belief. :Eeek:
stcyr
1,765
1,160
Normandie
We've got one of these wired into the solar gubbins... found it very useful in letting us know when to cut down on consumption... :thumb:
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I've got a couple of those voltmeters that fit into the 12v ciggie lighter sockets - one on the dashboard and one on the leisure battery circuit. Very handy because they're portable.
What's also useful is the little digital display thermometers with sensor - I fitted one to the MH fridge's front panel. Trouble is the readout in Southern France in August is frightening. We had one day where it didn't go below +16 degrees inside the chiller compartment, although the icebox remained frozen.
I've also got one fitted on the house fridge so I can see if the lodger's been leaving the fridge door ajar ;-)
Jan 24, 2010
2,440
4,850
Adria Twin
found one...
youll need to use a Isolated DC-DC converter for these, if you use the same source as it is measuring it will probably just short out or just not work at all
Alternativly take the 12v from the hab battery or vice versa if your measuring the hab battery
Feb 27, 2011
14,741
76,096
I don't follow you?
Jan 24, 2010
2,440
4,850
Adria Twin
Basically this amp meter needs a power source which is not directly from the same circuit you are measuring the amps or it won't work or will short out.
for measuring the hab battery, don't take the power for the meter from the hab battery unless you are using an isolating dc-dc converter.
Ooops ....just noticed in my previous post I should have typed..alternativley take the 12v from the Van battery or vice versa if you are measuring the van battery
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Being able to monitor amps used is obviously useful.
Battery voltage can be measured at the control panel or with a multi meter.
At the risk of indulging in muppetry............
I'm no electrical wizard, so have I got this amps measuring business right?
I have 2 leisure batteries totalling 185 amps, so I would need a device rated at say 200 amps?
The shunt would be spliced into the (+) outlet from the leisure batteries to the control panel?
The power source cant be taken from the leisure batteries?
Power source from the vehicle battery is ok, as the device would only draw milliamps?
From fag lighter ok, or hard wired?
Can a similar bit of kit be spliced into the AC circuitry, or is that unecessary?
14,741
76,096
I still don't follow you. Why should it short? I don't follow your logic.
The shunt is in series (usually on the negative terminal) then you connect the supply as normal. No short there....
This is exactly as it should be.:Confused:
Feb 27, 2011
14,741
76,096
No you just need a shunt that is capable of carrying your usage at maximum. I have 500AH of battery and a 100Amp shunt. Never seen it go above 35 amps when charging and never about 15amp discharging.
The shunt is usually on the negative terminal. Disconnect everything from the negative terminal of the battery. Connect one side of the shunt to the battery terminal then reconnect everything back to the other side of the shunt.
You can power the meter from the same battery. Not sure what bungy is on about here but hopefully we will get an answer soon and clear up my confusion:thumb:
forget the AC side not necessary.
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Thanks Grommet.
Sounds easy enough.
So....that will monitor how many amps being used at any given time?
Feb 27, 2011
14,741
76,096
Thanks Grommet.
Sounds easy enough.
And also how quickly you are getting charge in. for instance from a solar panel or main charger.
It's like a really rudimentary NASA battery monitor without the cumulative count/% left readings..
Wait for Bungy just in case I am missing something.
Jan 24, 2010
2,440
4,850
Adria Twin
Im talking about the meter shorting btw .....as most amp meters at the cheap end of the scale dont allow for a common ground between what is being measured and the dc supply that powers the meter. These are also generally used in multimeters etc so generally expect a seperate power supply
The wiring diagram on the both that are listed show two distinct circuits, one for the shunt and one for the power. So assuming they are correct....they need a seperate supply to what is being measured
Also need to be aware of where the shunt needs to be for the particular meter, most are designed to be in the - side, to eliminate common mode voltage....which the first one listed is. But some are designed for the + side. The second listing doesn't say which it is so may be worth checking with the seller on both counts to be sure.
Feb 27, 2011
14,741
76,096
I don't see how a common ground could cause a short. Can you point me at an internal circuit diagram that explains what you mean please?
3,996
6,256
Rochester
Auto-Trail Mohawk
16 fun filled years
Jim,
Sadly It's a very simple answer, Child Labour.
China’s child labor is a huge problem, and there is clear evidence that child labor is increasing in China. Although there is no official figure on the number of children working in China, it is estimated by many that of the 10 million children out of school, over 5 million are working in factories. There are some who even consider this a conservative estimate. It was reported in Sichuan, China’s most populated province, that 85% of children who drop out of school are working elsewhere. Even in some less populated rural provinces, over 20% of the work force is made up of children. Also, in the last few years, the rate of children kidnapped has increased rapidly. It is believed that the children kidnapped are sold off to factories to work. For example, in 1994, about 48 Chinese brick-shop-workers kidnapped over 100 children. It is known that fourty of those children were forced to work 10 hours a day, but with no wage whatsoever. China’s child labor cannot be overlooked.
And the two batteries don't share a common ground so both +12Vs effectively identical !
It looks to me like the ground is common to power and the shunt so the +12V should be fine to power it. The input will only go to an op amp, inside a micro, so it's common mode rejection should cope with any small differences, which on such a shunt will be tiny.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I bought this too, great Chinese price. Now my Baraldi cooker hood is controllable
CLICK TO WATCH VIDEO
2,440
4,850
Adria Twin
I don't have an internal circuit diagram for the meters hence the warning - lessons learnt and all that...but there are lots of examples on line...this pdf has a very detailed description ., bit of an old one but does go into what I think your after
Just to clarify - im not saying the meter will cause a short across the batteries...its the meter its self that can short out and die a death of a thousand wigglies
UPDATE - Just found this lot...http://www.datasheets.org.uk/500--digital+Ammeter+circuit-datasheet.html
update again - forget that - you have to pay for them!!
the two batteries are normally isolated from each other by charging systems etc - so don't actually function as one battery so are, for the purposes of the meters, Isolated supplies ::bigsmile:
It all depends on the meters design...if it has been designed to work that way - then no issues, but if it has not it will at best display incorrect info or more likely just not work. and at worst the meter will burn out
this one for example doesnt need a separate supply Link Removed where as this one, from the same seller, does
The simple fact is that some require a isolated supply and some dont, hence why I said its worth checking with the seller -
So you can either buy one that doesn't need an isolated supply...or buy one that does and use a isloated supply, or just give it a go and accept that it may not work
forgot to add that if your going down the route of installing an Amps one and volts one... you'll definatley need a isolated supply
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Wonderfully confused now.
In simple terms:
Monitor the leisure batteries through a shunt (in + or - ?) and take the feed for the meter from the vehicle battery (minimal amps drain)......all safe, should work....yes?
2,440
4,850
Adria Twin
In simple terms:
sorry for the confusion::bigsmile:
from my point of view....yes it should, you could also add a switch into the circuit to turn the meter on an off, which will help with the battery drain. Shunt should be inline in the -ve wire from the battery, and as close to the battery as possible.
Make sure you get one that can cope with 12v power supply, or you will need a DC voltage converter to drop the 12v down to whatever the meter needs...which just adds complexity and cost.
Best bet is to get one that can accommodate a range, most of them have a range from 4.5v upto, and beyond 15v - one of these would be ideal
One thing - dont expect them to overly accurate(+- 2-3%)...a good guide line but not a precision info...to get very accurate needs shielded wire and some other bits and bobs!! but again all dependant on the design of the thing...
Feb 27, 2011
14,741
76,096
Thanks for the information Bungy. I will look into it in more detail later when I get some time. I will take your word for it though.
I have set up meters before using a shunt and not taken this into account (both v and a meters) and never had a problem.
I am struggling to imagine a circuit with a fault mode caused by using the same supply but you have obviously experienced this...
My practical experience of electronics comes from being a radio ham, having a tv/VCR repair round (many moons ago) as well as my hobby electronics from 20 years ago. It is all well out of date now so I will bow to more current knowledge on this.
A quick fix for the would be to use a PP3 (9v) battery and a momentary push action button to turn it on.
11,843
14,080
I have bought the odd cheap meter and would suggest checking against a known accurate meter. So for example a volt meter I bought reads nearly 10% low, which is no problem as long as it is known, and for a lot of purposes it really doesn't matter though it might if it was even further out.
As long as the two battery system negatives are connected together, ours is, then as far as the +12V is concerned the meter will not know the difference between either 12V. You cannot consider either to be isolated.
I've been tossing this round my head all night.
Why ?
I can't work it out.
