VFD-Variable frequency drives for my beautiful drill- advice please (1 Viewer)
Nov 2, 2014
332
295
Maldon Essex
Should do the job the advantage of the inverter is it can be used on any other 3ph machine you might want as long as it's 2hp or less you will need to change the links in the from star to delta
Chris
Enword
1,900
7,999
Devon
Coach Built
Race van conversion for years
I know you can get 3 phase to 3 phase, not sure about single to single?
Nov 2, 2014
332
295
Maldon Essex
I work on machines with inverters most days it is not unusual to find small inverters below 2.2kw 3hp which are single phase input 3 phase 220 volt output most small motor's can be linked for 220v or 400 operation
Chris
Dec 12, 2010
5,439
21,718
Cumbria
since 2011
Hi @bubble63, let us know how it works out, something like that would probably run my small surface grinder. I was looking at VFD's in the adverts in Model Engineer and they are twice the price of the one you've listed (y)
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Chris
hi chris
my motor has lots of terminals 1-6 I think, 2-3-4 are linked with copper strip
so... not sure if its in delta or star right now:cool:
the previous inverter ran the motor just fine until its untimely departure:( [so perhaps delta?]
I dont understand if i need to respect polarity when I connect the motor/inverter,
the inverter output is marked U-V-W ??!!o_O
anybody have any tips?
Nov 2, 2014
332
295
Maldon Essex
Could you post a picture of the motor plate and the inside of the terminal box
Polarity don't matter if the direction is wrong just change any 2 of the connections
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Nov 2, 2014
332
295
Maldon Essex
The motor is connected in star 415v to change to delta remove the links fit the long link between 1 and 6 then small links between 2 and 3 ,4 and 5 leave the power connection where they are.
Check the resistance low ohms between the 3 power cables 3 times between 1 2 then 1 3 and 2 3 should be the same within 10% the link setup is a bit of a guess it's a unusual setup.
Was the old inverter 220v 415v output or the motor has been rewound or it was run on 220v would of run but lack power
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
I think I agree with you , its in star
looking at the diagram above I also concur with you wiring suggestion
I'm strangely motivated by this little forage, its been 35 years since I really touched this kind of stuff:)
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
@hchris said
'Was the old inverter 220v 415v output or the motor has been rewound or it was run on 220v would of run but lack power'
great question, I literally fished the old/ brand new convertor out of a skip, connected it and it ran, never thought anymore about it
[Dont suppose you know anything about 60's rolls royce V8 chokes do you, as that the other thing thats perplexing me at the moment;)]
neil
Nov 2, 2014
332
295
Maldon Essex
neil
At a guess over complicated and expensive ??
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
I'm going for complicated as I don't think I need parts, they just don't come off choke at the appropriate time
I'm buttering up an aeronautical engineer as it very similar physics
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Ok an update
The VFD arrived and won't work
In delta it just turns the motor slowly and in star nothing
The instructions are next to useless
I have initiated a return thro eBay
The seller is twisting and turning and does not want a return, hopefully eBay will step in
I have found a second hand 1/2 horse motor
So back to plan A or was it B
Thanks for the motor offers but I think a 1/2 is required.
Neil
Nov 2, 2014
332
295
Maldon Essex
Not familiar with that Inverter when you tried it did you set the frequency 50Hz will give normal speed.
Chris
bubble63
Aug 10, 2012
844
914
cambridge
Globecar
since2001
Yep 50 hz
tried every thing I could think of
The vendor is just shipping boxes, they don't have a clue
I found a motor from a myford lathe will fit
