Van security (1 Viewer)
ShiftZZ
21,383
84,579
Dark Side of the Moon
I have seen these being advertised.
I was wondering, would you not be as safe if you used two bike chains, threaded between the door handles?
Pros/Cons?
GJH
29,450
38,827
None, now sold
2006 to 2022
The factor that has put me off using any similar locking device on the cab doors is that it creates an extra difficulty should an emergency occur which necessitated using the cab doors to get out.
I can see that the risk of somebody breaking in through the cab doors would be raised when camping off-site but I've never been concerned when staying on sites/rallies/meets.
Aug 18, 2011
12,140
18,005
derbys
AUTOSLEEPER SYMBOL
Those Fiamma bars are useless. Handbrake cable made to size with loop on each end and a padlock for when van is empty and a clip when you are sleeping. Cheap and simple.
Feb 16, 2013
19,735
52,033
uttoxeter
ambulance conversion
50 years
You know, them locks that you see on some habitation doors that sort of turn down and lock, how do you get out if some emergency occurs , had nothing to do with them and always wondered.
Jim
Ringleader
Jul 19, 2007
36,421
130,933
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Those bars work OK as a deterrent and are best used when you leave the van unattended. They don't stop determined entry, (especially so if they are fitted like they are in the photo) They can be removed very quickly should you need to drive away in a hurry. Heosafe locks are a MUCH better option but as they cannot be seen, don't offer much deterrent.
Normally if I'm parked up where I feel the need to chain the doors, I'm not sleeping:Smile:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
I don't have any cab doors, so don't have to worry about locking them. Regarding emergency exits, there are windows all around the van....must go on a diet :Doh:.
Feb 16, 2013
19,735
52,033
uttoxeter
50 years
You have only got to look at the windows in mhs to see its a waste of time putting extra locks on the doors, you could be in most windows with a pen knife in seconds
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I have one of those bars, but have never used it.
Tried it "on for size", it looks like it will deter a thief in that there is a device in place.
We can fit as many security devices as we like, they are only deterents.
A determined, professional thief will get in given enough time.
Security devices in view may encourage a professional thief to go elsewhere, that's all.
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I made one of my own with a length of wood with metal angle brackets on either end. In the middle of the bar is a webbing strap with a quick release clip connecting to another strap that's anchored to the driver's seat base. That way there's a deterrent plus the ability to get out quick.
Overnight the insulation's up inside the window so a would-be thief wouldn't see the bar and would have more difficulty opening the door. By the time they'd got past it the alarm would be sounding. If we're not in the van I put the bar across and run cable padlocks between the steering wheel and the driver's door handle, and between the seat arm rest and passenger door handle. The cables hold the bar tight down on both sides.
