Using Aires with barriers at entrance (1 Viewer)
Feb 24, 2013
13,083
101,459
Bolsover, Derbyshire
Hymer S800
not long enough
So we are off again next month, have now used aires throughout France with reasonable success, some lovely locations, some we would not go back to, but a couple of couldn't get in's that I am keen to sort out for the trip in February
We have so far used about 20 different aires, (quite a few repeats), virtually all with unrestricted access, mostly found from All the aires book, or Kamper Contact app, or suggested on here
Our failure and therefore concern going forward, some have a barrier to get past at the entrance, we failed at the only one we have tried, a little village near the Somport tunnel (actually the col option nearby) large tarmac area, could probably take 50+ MH's no obvious reason why based on size of town, 2 French registered MH's already in and the place totally deserted. Up to barrier, nothing, so get out to look at it (the machine not the barrier) couldn't make sense of it, so offer it our Caxton card, nothing, try my UK debit card, still nothing. Stand back and have a longer look from further away really hoping that one of the French MHers would return and help, nothing doing
It is now getting late in the day and we have driven quite a distance already, but prefer to be stopped before it goes dark, so move on, as is often said you will never have to go far to find another, we did find one close by but did not like the location, on this occasion we ended up very nicely in a temporary aire alongside a grape processor, which was also alongside a bakery and pizzeria, :)(y) so good result all round
The only other pay for aires, one they said it would be called for, but nobody ever came (Niort), there was one other, as close to a CL as you could ever come across, 15 miles from Calais middle of nowhere, run by a lovely lady who wandered over to see us as we arrived and took a bread order for the following morning, heaven only knows where she got it from there wasn't a shop in the village, but it was on our step at 07:00 :), we paid her cash on arrival so nice and easy there
But I still need to know what do you lot do to get the red and white arm to raise?
Khizzie
3,794
5,695
Le Repaire,Thiviers,France
Autocriuse stargazer
since 2002
Viagra..!!??
18,032
48,109
I suspect it is one of these things which only takes a French card. I had hoped my Brittany Ferries money card would work in them - but it doesn't!
Hollyberry
5,518
42,265
New Forest.
None.
4yrs
Either coins or jetons? Usually bought at Mairie/ Tourism Office or local shop. Should say in Aires book.
Looking online, looks like you needed jetons at that one.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
I don't even remember where I was, will try and identify it now :)
If you need jetons are they universal? if not I guess there is no point arriving when the office would be shut, I don't recall seeing any words to that effect though, it definitely had a slot for a card (y)
Edit, I reckon it was Laruns
Aug 15, 2014
2,580
3,462
Exiled in Yorkshire
Pilote 600L
I believe you can yet the jetons from local tabacs etc, I have experienced this in the past and being unable to find a jetons outlet I simply moved on
teensvan99
231
250
Margate
We have used 100s of Aires over the years and never yet seen two barriers the same. Funny one was Dutch couple could not get out of Aire even with help of French. Plan B was unbolt barrier drive through and refit. We did get out ok. I always let Ann sort it out. None of the German stellplatz barriers seem the same either.
Jenben
2,239
206,389
Uk
Hymer Exsis I
We have every now and again found that our cards just won't work on some of these barriers. We have a variety of ccards and this hasn't happened often ( once or twice ) despite using a lot of aires. I think they sometimes just havent been ' mapped' to take UK cards. In one I remember a French camping cariste who saw us trying to get in and failing then used his ccard to let us in and we paid him the cash. :)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
1. I keep a tub of Euro coins handy in the MH.
2. Failing that I use a Santander Zero Credit Card which is authorised for use in Europe and doesn't charge an exchange fee for it.
3. If there's not a foreign card or cash option and it doesn't use jetons I'd give up and head for my Plan B aire, but it hasn't happened yet.
If jetons are needed there's sometimes an automated dispenser on the aire itself, otherwise it's off to the Mairie. I don't see jetons very much these days.
We occasionally have problems getting out of the Bois Plage en Re aire as it doesn't like our card, but it's attached to a campsite so the reception will sort the barrier out.
The only other one that proved problematic a while ago was at Lacanau-Ocean, where it was OK getting in but it didn't accept the numeric pass code on the way out. Sticky keypad? Don't know. Someone else typed their code in to raise the barrier for us. Otherwise I'd have cycled down to the Mairie.
The worst obstacle I've encountered to entering an aire is when they dispense time sensitive tickets that don't expire when the MH owner departs the pitch. You get a 48 hour ticket and that's it, your pitch is booked for the full 48 hours regardless of when you depart. The entry barrier won't operate until the next ticket expires, even if the aire has loads of empty pitches. I was once caught in a ridiculous queue on a hot day at La Palmyre, all waiting for the tickets to expire on the numerous empty pitches. I've got a feeling the barrier may have been reprogrammed since - I bloody well hope so.
denisejoe
5,617
12,051
Warden isle of sheppy
Seeing as you put a credit card in I can't see it being a jeton. Also was you close enough to the barrier as I know that on a few you need to be very close to the barrier in order to pay for it.
Joe
Nov 4, 2011
5,942
38,997
Uk
I have used the barrier type on Ile du Noirmoutier and I think I remember you had to get a ticket which had a number on it, this number let you in and then you had to pay to leave ( this maybe be b......ks but I think that's how it worked). Even had to help some French who couldn't work it out.
Nov 11, 2013
1,959
6,893
Tewkesbury
Hymer T-SL 668
March 2014
I was told that no UK cards will work anywhere in Brittany as there is a problem with the central softwear that controls the barriers. The Tourist Office in one town told me to ask a local to pay for me with his card, so I tried this at the next aire we visited and was told curtly by one guy drinking wine with his mates to get lost and go to the Tourist Office and pay!! I went there and told them what had happened and they were surprised and said French men were usually kind and good mannered! Doesn't quite fit with a shopkeeper in a very posh patisserie in Deauville where I foolishly asked her if she spoke English. Without realising I could speak a bit of French so understood most of what she said she replied "no, but I speak f***ing good French......."!
The Brittany problem may possibly exist elsewhere in France?
denisejoe
5,617
12,051
Never had a problem paying at any barrier, or anywhere else, with our English credit card - we carry both Visa and MasterCard and even if one won't work the other will.
Denise
Mar 16, 2010
3,057
30,772
Carmarthenshire
In between
Since 1988
Yes we had that somewhere near Mimizan we tried for ages to work it out until a French leafy came over and told us we had to put our vehicle registration into the machine and then be given a ticket that had to be put in the exit machine before putting in the debit or credit card to pay ...and yes it worked and it let us out the following day once w had paid.
Not sure if it was a new system but even the French were having problems and "madame" was kept busy walking backwards and forwards to show everyone how to use it.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
and I thought I was worried about getting in :)(y)
Jun 17, 2012
2,933
9,933
North Essex
Autotrail Delaware
>12 but <13
= Up to barrier, nothing, so get out to look at it (the machine not the barrier) couldn't make sense of it, so offer it our Caxton card, nothing, try my UK debit card, still nothing. Stand back and have a longer look from further away really hoping that one of the French MHers would return and help, nothing doing
Perhaps barrier needed a Credit card as Caxton and debit cards are sometimes refused.
Some French had trouble getting into Gaste last year. Nice French guy used his card and let us in, including me.
D
Deleted member 29692
No. There are 3 or 4 main types that will cover you for most places. I usually buy 2 or 3 whenever I come across them so I've go ta bit of a stock in the van.
I thought they were mainly for water and electric though rather than barriers.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
Thanks, that was my thought as well, we might be sticking with our current plan and only using the free aires :)
sedge
Jul 7, 2009
5,504
13,117
Nr Jct 3 M6
Aug 09 to date 9,000 miles!
We wanted to stay 2 nights at Gaste - but the card thing was broken and we literally only had cash for 1 night having thought we'd spot a hole in the wall on the way, but hadn't. And the cash one didn't accept notes. And most of the aire was flooded - but apart from that it was lovely! LOL
Jenben
2,239
206,389
Uk
Hymer Exsis I
@DavidG58 , don't let it put you off or limit where you stay, often stories of things that have gone " less than perfectly" give you an amusing story to share with others.... :) clearly much much later.......... Enjoy your trip to France.
KeithChesterfield
528
1,234
Stand Road Chesterfield
Low Profile
To use the system on one like this pictured below you have to put in a Credit/Debit card and follow the instructions (use the Blue buttons to go up or down).
After you put in your 4 digit pin you are asked to wait and the machine prints out a 6 digit pin number on a paper ticket and the barrier opens.
To get out again you have to enter the 6 digit pin and the barrier opens.
If you are able to use coins just follow the on-screen instructions (find English by using the Blue buttons) and the system works the same – Validate using the big Green button or, on different machines, the one with V on it.
If having problems, or the Frenchman behind you is tutting and sighing, press the Red button to cancel the transaction - and watch how he does it.
At least that's my understanding of the way to do it!
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
There is a new company in France setting up Aires called Camping-car-park.com. They have barriers on their Aires and you have to pay and register with them( at the barrier) you then get a plastic "debit card" from the machine that you can load with money to use in their Aires. Cost is about €9.25 per night.
Great idea, but took us ( and a couple of locals helping out) over half an hour of fiddling about with it to get it to work. In the end we had to phone the helpline and get our card validated.
But, if a private company can build and operate Aires in France and, presumably make a profit, why doesn't someone do it over here?
Wyaye wires
3,333
9,263
Berwickshire
A class Neisman Bischoff
since July 2009
Be British man...
Carry a hacksaw and move very early next morning!!!(y)(y)(y):whistle::whistle::whistle:
D
For exactly the same reasons as every other time the question is asked - different planning law, lack of demonstrable demand, prohibitive cost in obtaining and converting suitable sites, totally different profile of people touring in Britain, far fewer people touring in Britain, the list goes on.
You can't compare France to the UK. We really don't need to go over it all again do we?
Allanm
5,431
9,192
Since 1987
No we don't, but those excuses are always rolled out with, as far as I can see, no real evidence
Over 2500 new motorhomes were registered in the UK last year, if Canterbury can build an aire and charge £3 a night, with free access to the Park and Ride, there is no reason other councils cannot do the same, and no reason private companies can't approach councils with a view to providing them themselves.
Years ago, there were very few motorhomes in Europe, but forward thinking people planned for them and they must have faced planning laws and low demand at the time.
D
The most damning reason why not is that there is very little demonstrated demand elsewhere. Nobody is going to spend the money on the off chance and £3 isn't a commercial rate anyway. Most of the people who are demanding that councils be forced to provide facilities would baulk at being asked to pay more than a token amount. How would you feel about a facility little more than a car park operated by a private company that wanted to charge you £15 per night? If private companies are involved they will expect a profit.
Canterbury has a unique situation in that it is an obvious and convenient stop over both for the channel ports and the tunnel. How many people do you think would be using the facility otherwise? Very few other places have that ready made demand. Canterbury also had the facility almost ready made with water and waste services almost adjacent. The investment they would have had to make would have been minimal.
How much demand do you think there would be for such a facility in Basingstoke or Wolverhampton? @GJH will be able to tell you more about the facility provided at Guisborough because arguments like yours were accepted. I believe it had less than 5 visitors in the 18 months it was open.
If you are just talking about allowing access to P&R car parks and nothing else then maybe that would be a starting point but if you want water and waste facilities provided then you need to be able to demonstrate with accurate figures how long it will take the council in question to recoup it's investment, which as shown by the Portrush example could be significant.
Personally I would love more of this type facilities to be available here but I'm not naive enough to think that anyone is going to provide them without some very serious demonstrations of viability. Unfortunately, apart from a few special cases like Canterbury, I don't think that viability is there.
DavidG58
Feb 24, 2013
13,083
101,459
Hymer S800
not long enough
@NickNic @Allanm
I only want to know how to get into French aires, I didn't want to be the spawning ground for a spat on UK aires
There could well be others looking in for answers to the same question, they like me don't really want to have to wade through 'another' off topic battle (y)
Go start your own purpose made targeted thread maybe :)
GJH
29,450
38,827
None, now sold
2006 to 2022
There is nothing to stop a private company - or an individual for that matter - from doing so, other than the fact that they would not want to waste their money.
Time and time again I have appealed in posts on here and elsewhere for people to identify land where they live (or in towns they know) which could be used for aires and then approach the owners to make a case for them opening an aire. A handful of people have done so, that is all, demonstrating that the demand does not exist.
EDIT - Sorry @DavidG58 you posted whilst I was typing.
