URGENT should my voltage be moving about so much
Discussion in 'Solar Power' started by campa cola, Aug 17, 2016.
  1. campa cola
    campa cola Funster
    Oct 5, 2012
    3,068
    5,954
    Weegeland
    Just got a baird 100w flexi panel. I am using and mounting a watt meter (ebay) with the panel and have noticed the voltage is moving about constantly between 14-22 volts even on a constant sunlight and the panel is stationary without shadow. Is this normal ? Thanks for any advice.
  2. hilldweller
    Dec 5, 2008
    27,723
    26,814
    Macclesfield
    Way too high. Ours cycles 13.6 to 14V constantly when charged.
    Is it meter user error or a serious fault ?
    Are you measuring the panel not the battery ?
  3. campa cola
    campa cola Funster
    Oct 5, 2012
    3,068
    5,954
    Weegeland
    The watt meter is directly measuring the panel output ! Not the battery So maybe thats ok then ?
    • Like it Like it x 1
  4. hilldweller
    Dec 5, 2008
    27,723
    26,814
    Macclesfield
    Oops, missed that, it's a bit unusual. Yes, sounds fine. 20V when off load and 14V when it's feeding the battery.
  5. Eddystone
    Eddystone Funster
    Feb 26, 2012
    284
    166
    If you are measuring volts, you must be using a volt meter. Are you able to switch the meter between volts and Watts?
  6. campa cola
    campa cola Funster
    Oct 5, 2012
    3,068
    5,954
    Weegeland
    It measures both volts and watts plus a couple of other things at the same time. But the values are moving about a lot.
