Under-dash power take-off point... (1 Viewer)
gusthegorilla
10
15
Withernsea
Tracker EKS SE
I'm a newbie
Hi all,
I have a 2008 Autotrail Tracker EKS, Fiat-based.
Whilst driving it home from the supplier, I noticed, as I now know thousands more have, that the radio reception is up and down like a bride's nightie, so recently invested in a Blaupunkt screen-mounted powered aerial in an effort to improve said signal!!
While I had my spending head on, I also bought a Nextbase 312gw dashcam.
BOTH of these require 12v to make them go, so please can anyone recommend a suitable take-off point, preferably ignition controlled?
Mechanicals are my forte, sadly electrics leave me cold:eek:
Many thanks,
Gus:D2
Sep 10, 2012
2,139
3,793
worcester
Sunliving van
Tap into the back of the 12v outlets on the dash next to the cup holder.
Many threads on here on this if u use the search
53,684
150,937
For the aerial the radio will have a lead that is powered when the radio is turned on. For the dash cam about 3 quid on eBay you can buy USB power supplies and the wire it to the +ACC feed (ignition switched feed on the radio). .
gusthegorilla
gusthegorilla
10
15
Withernsea
Tracker EKS SE
I'm a newbie
Thanks very much, guys....thought that was maybe too obvious, clearly the way to go though :)
Appreciate the tip about individual fuses.
KR,
Gus :D2
53,684
150,937
Spade connectors better...scotchlocks in desperation.
Tell me about it, doing all the mods on my new van I've used insulated crimps or soldered wires, one place not enough room to get crimp tools in so resorted to Scotlocks, bl**dy problems that gave me.:cry:
43,371
49,744
If I HAVE to use scotchlocks I strip back a little insulation and fold the conductors over so doubling them.
Seems to work
43,371
49,744
Seems to work
Hmmm! Don't know what happened there.
53,684
150,937
Seems to work
Try doing that when working through a 5" sq hole at the side of the inside of an overhead locker without clear line of sight.
WSandME
368
453
Wigan-ish
Hymer B660 Bestline
SInce 2006
Although similar to Scotchlocks, I used to good effect when fitting several USB charging points throughout the Hymer.
Never seen those before, brilliant if you may want to disconnect later.
Now, do I need yet another box of bits ??????????
Dec 10, 2013
3,426
12,324
South Staffs
Pilote P740GJ
Our next door neighbour papered his hallway through his letterbox, mind you he is a gynaecologist.:)
