Unblocking bathroom sink (2 Viewers)
Tessntim
58
7
Devon
Fiat ducato
My bathroom sink is blocked any good ideas how to unblock the pipe as Iv tried sink unblocker boiling water but nothing need advice
makems
3,440
27,702
Ingleby Barwick,,Teesside
Sadly had to give up
Do you mean the bathroom sink in your Motorhome?
I recently resorted to removing the trap underneath mine as it was emptying very slowly.
It was gunged up with toothpaste slurry which took me a while to clean out. I think it's because we try to economise on water and the toothpaste doesn't get flushed through properly.
Bobby22
1,537
6,408
Rapido 680ff
since 2013
Fenwicks do a pipe and tank cleaner for motorhomes.
Tessntim
Tessntim
58
7
Devon
Fiat ducato
The pipe is sealed to under van as it comes out the bottom dost look a easy job to get pipes off from under van .. Eek
Tessntim
Tessntim
58
7
Devon
Fiat ducato
I had the pipe off from under sink Iv gone down as far as it can see inside van as we'll
Feb 1, 2011
209
146
Redcar
Hymer C. Class
26 yrs
Go careful with the plunger, I was a bit heavy handed with the 'suction and managed to crack the drain well cover, they don't sell just the cover, so it was a new 'Trap' which are a bit of a 'Pain; to replace.
Now I use a non corrosive 'drain clear' and hot water and leave it over-night.
Life can be a pain sometimes??? Best Regards Mac
CWH
5,150
247,496
WildAx PVC
From November 2013
baking soda/ soda crystals and vinegar works well in an ordinary bathroom
somebody will be along soon to tell you/ me whether this would damage MH fittings
D
DM14742
Hot water & soda crystals (leave for a couple of hours) then garden hose from mains supply to flush through
g8ysn
638
417
ng219ep
every so often i put a cheap bottle of coka cola down sink.s and shower ,.shower tend,s to clot up more what with shampoo and shower gell,when flushed let hot water run through ,sink i took out and put in house u bend ,also helps keep waste clean/clear
Apr 13, 2012
5,545
18,775
Mobilvetta Euroyacht
1996, then break 'til 2011
Sometimes there is no choice but to take the trap/pipework off
Apart from hair - hard to remove with chemicals - one of my boys completely blocked not just the trap but the next elbow in the pipework with dozens of cotton buds !
x:-)x:-)
magicsurfbus
4,673
10,127
NW England
Bessacarr Coachbuilt
Since 1997
I've just had to do our house shower plug - I used one of those long curtain wire type thingies with a winding handle on the end, and it eventually sorted it. The substance I find least useful is Mr Muscle. I sometimes get a result by powdering a dishwasher tablet, mixing it with washing up liquid and sending it down the hole with a goodly dose of boiling water. In the past I've used a short length of hose from the tap, pointed it straight down the plughole, bunged up the gap between them with a flannel, then opened up the tap. It'll either clear the blockage or come gushing back out of the overflow.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I always eat three portions of 'Uncle Trumpers' best Lancashire Quality mushy peas, drink two pints of Guinness, wait one hour, and use my ass bugle. Works so well, not only clears my sink, but everyone else's for ten houses each side. :xThumb::xThumb:
A MH is just like your home, standard plastic pipework, so if it works at home it works in MH.
That guy gets me, "don't use chemicals". So vinegar is, I think, acetic acid and other things, sodium carbonate is as chemical as it gets, an alkali. Mix it with an acid and it gives off gas and heat. Rant over.
But not your toilet, that has rubber seals, don't use bleach.
Apr 13, 2012
5,545
18,775
I was told on here not to pour boiling water down a sink...........much later I thought "where do you pour the water when you've just boiled veg ?"..................
..............down the sink
:xdoh:
Daifuse
183
310
Milford Haven
c class
Since 2011
I waited in a neighbours house for her (she works) for the dishwasher maintenance man. When he arrived, he decided that the problem was an excess of grease, fat, etc. was the reason for it's malfunctioning. He extracted a bottle of 'Comfort' from his toolbox and proceeded to empty the total contents into the machine, squirting it all round the inside surfaces. "Best thing for getting rid of the gunge" he proclaimed, putting the machine on a short programme. And it worked. After that, cutlery, dishes and every thing else came out sparkling so my neighbour informed me. "It hasn't worked that well since it was new"
Reactions: CWH
tinkering
222
1,105
dorset
Do you have a tip up type of sink?
If you do you might find that you have accidentally lost a bar of soap or two when you ( or your grandchildren ) have tipped up the sink
Sep 23, 2013
2,585
8,773
Lincs
Globecar Campscout
Very true.
While he may well be correct about vinegar & sodium carbonate making a good combination to clear a blocked drain, everything else sounded complete rubbish to me. Either he wasn't paying attention in his 3rd year chemistry lessons & is now innocently misleading others, or he knows it's rubbish & is relying on other people's lack of knowledge to peddle his own brand of snake oil.
May 24, 2016
30
25
North Somerset
Since 2016 - this time
I've just got back from my sons garage where he put my motorhome on the ramp so could get to the waste pipes as the bathroom sink was blocked. Had smell from pipes, thought was the shower, but then saw the back panel where the drop down sink fits was getting mouldy. I looked inside the 'funnel' where the water drains out & it was almost full! Took the sink off & drained the water using a cloth, put some bicarb & vinegar down, didn't do much. Drained out again, tried washing soda, didn't do anything!
On the hose from the sink there's been a short piece of straight pipe fitted, took 1 end off & no water came out. Got the air hose & blasted through from the sink end ..... this is what came out - 20190916_113601.jpg
Lump of silicon with a small hole in the middle. They'd used silicon to seal the joints on the pipe! No wonder it was slow draining, wonder it drained at all! I'd dropped 2 small soap bars down too. Anyway, sorry for long post ? in future I'll be removing the sink (quite easy to do) if drop anything, tho I'm using liquid soap now.
Jan 23, 2016
1,890
305,496
Wales
Adria Coral 660SP
25 years
I have a similar problem in my apartment so took to spitting into the loo.
I have continued the habit in the MoHo.
