Ultrastore Series 3 (I think.....) (1 Viewer)
Jerrymjj
100
27
Alton Hants
Autotrail Tracker SE
Newbie!
Came to check the water boiler on EHU before going away for first time since Autumn (I know, I know) and surprise suprise, it doesn't work. Power at the 13amp socket, fuse on the unit both fine. But nothing happens. All dead.... Any thoughts? I'd be enormously grateful. Cheers, Jerry
Feb 22, 2011
9,787
20,152
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Hi Jerry, I`m afraid I`m a bit of a novice in terms of motorhoming so I`m going to be of no use to you whatsoever, but I do know the techies on here will soon be along to give some good advice and the first question is usually what type of boiler do you have. eg model number ?
Chris
Edit : oops, just seen it in the heading ! I`m sure you`ll get some replies soon
Jerrymjj
Jerrymjj
100
27
Alton Hants
Newbie!
Thanks for your advice Figaro but problem now solved and it was all my own stupid fault. I filled the water tank on the van but forgot to turn on the pump switch. The boiler tank has to be filled via the pump so when I turned on the heater, there was no water in the tank. Fortunately, the thermal cut out switched it all off so when I returned this morning to start taking it apart, having realised my error and filled the tank via the pump, all was well. We can go away!
Reactions: f6c
