Tyre woes
Discussion in 'Tech/Mech General' started by olley, Jun 18, 2008.
  1. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    hi just decided to check my tyre pressures, all OK until I get to the nearside inner, the valve don't work :Sad: tried pushing it in with a screw driver but nothings coming out, I don't think its flat so called a mobile tyre service out. £35 to remove replace the valve and refit.
    Seeing as it would cost me that in fuel to drive to their yard 5 miles away I said OK. :BigGrin:
    Olley
  2. ourcampersbeentrashed
    ourcampersbeentrashed Funster
    Apr 19, 2008
    7,652
    4,284
    East London
    Ohhhhh Olley hope you day gets better xxxxxxx
  3. pudseykeith
    pudseykeith Read Only Funster
    Nov 5, 2007
    382
    105
    Leeds West Riding of York
    hi Olley.
    Sorry to hear about your tyre problems.
    A spare tyre valve and a small extraction tool would cost a £ or so is worth carrying as a spare. Also a foot pump would also be needed. changing a tyre valve needs no skill at all, just a tad of care. Would carrying one be a worth while addition to the toolbox ?
    pudseykeith. :thumb:
  4. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    Hi Keith I can push the centre of valve in without any air coming out, which means a) the tyre is flat or b) the valve is knackered
    It maybe that if I removed the valve I would be greeted with a blast of air, but inners are a bugger to get to, so I took the easy way out. :BigGrin:
    I will have a look around and see if a long valve extractor is available, probably need to be on a flexy drive. Wonder if they do a 1/4 drive one, then I could use the flexy in my socket set.
    Olley
  5. superk
    superk Read Only Funster
    Aug 22, 2007
    503
    57
    Devon
    Do you not have valve extenders fitted - makes access as easy as the outer tyre?
    :Smile:
    Keith
  6. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,854
    6,108
    Mansfield,Notts
    They cost about 2 call outs:Eek!:
    No flexible tool to my knowlage Olley only short and longer for comercial tyres, and they are normally double ended so no hope unless you can adapt one
    it is asumed the wheel will be "orf" if your playing with valves:Doh:
    ps if you need a spare or two valves give us a shout
    Geo
  7. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    Hi guys embarrassing, bad and expensive news.......:Blush::Blush::Blush:
    The tyres flat, its also knackered :cry::cry:
    He reckons I have been running it flat, and theirs what looks like a slight bulge in the sidewall, it may be OK but he wasn't happy to refit it. I think whats happened is that after Dave of Dave's motorhome services did the brake service the valve extender has been leaking.
    I have the type that have a stiff wire running down them to operate the tyres valve, and if you don't adjust them correctly just bending the flexy a different way can cause them to operate the valve and the air will slowly escape.
    I knew this and didn't check them after he did the service :Doh: all you have to do is remove the cap, if air comes out they need adjusting. Anybody know where I can get a Michelin 245x70x19.5 from?
    He fitted the spare so I am ok to run.
    Olley
  8. Sheelagh
    Sheelagh Read Only Funster
    Oct 14, 2007
    43
    Lancashire
    Tyres
    Don't know the full story cos don't listen half the time but Alan is away up in Scotland somewhere near dromnergrokit (apologies for the spelling) and had a puncture in his Rv inner back wheel. AA came to change it but the spare wheel in the lovely silver case on the back was the wrong size tyre for the wheel. So word of advice always check the spare when you buy a motorhome, Hoping he's on his way back now will speak to him later and listen maybe
  9. geoff1947
    geoff1947 Read Only Funster
    May 20, 2008
    999
    92
    Plymouth
    Tyres
    I know you are a long way away from Plymouth!! but if anyone in this area is following the Forum the best tyre repair/fitter is Ridgeway Tyres in Plympton. They are great lads and don't rip you off. I popped in recently for a query and the boss checked all my tyres and for FREE. Not many of them about !! I have used him for years for car and Camper van tyres and the prices are usually cheaper that say ATS or KWIK FIT. Hope you sort your problem out and it's not too expensive:Doh:
  10. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    Hi Geoff all I can get a quote for at the mo are Coopers £274inc vat and delivery.:Sad:
    Olley
  11. New Rover
    New Rover Read Only Funster
    Aug 31, 2007
    286
    Sheelagh, would that be Drumnadrochit?
    LOLOL
  12. Sheelagh
    Oct 14, 2007
    43
    Lancashire
  13. superk
    Aug 22, 2007
    503
    57
    Devon
    Hi Olley
    I did a big search for tyres in 2006 and spent hours on the phone so I don't know if the infomation is correct.
    19.5 as you realise is an odd size.
    Michelin XZE2 were available from Burnt Mill Tyres (nr Basildon) tel 01268 727742price £210+VAT
    Continental were £170 + VAT - PRICES INCLUDE FITTING.
    Cooper Tyres are sold in the UK as 'RV' tyres - I don't know how as in the US the same tyre is sold for 'local trucks'.
    Do make sure the load and speed rating are compatible.
    If you can't get the Michelin then Good Year are probably the easiest to find and I checked with Good Year technical department what was best - they recommended
    Good Year RHS - I fitted 6 - the ride was much better than the original GY RV tyres.
    I got a special deal on 4 GYs from a truck tyre place in Barking, London but had to buy the other 2 from Hi-Q at £187 + VAT inclusive of fitting.
    Hope that helps a little.
    :Smile:
    Keith
  14. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    Hi Keith thanks for that info, much appreciated, going on the Cooper website and putting in the details including 1750kg load rate comes up with the RM160 which is the one Sintons sell so I think that will be OK.
    The tyre fitter reckons he fits 19.5 to some coaches he has the contract for, he's going to check ratings and ring me tomorrow so it looks like one way or another I can get fixed up. Just need to spend some loot.:cry:
    I will phone Burnt Mills tomorrow and get a quote.
    Olley
  15. olley
    olley Funster
    Jul 29, 2007
    3,860
    2,449
    Ipswich
    Hi Keith just phoned Burnt Mills, he says my size are common truck tyres, so no problem with supply. He's got Michelins at £280 Bridgestone at £189 and Hancock at £149.5 all plus vat. The Hancock has a higher load rating than my Michelins and a speed rating of M (81mph) as the Winnie is governed to a max of 80mph that should be fine. :BigGrin:
    In his opinion the Michelins are overpriced, the Bridgestone are an equivalent quality to them, with the Hancocks slightly less, so I think I am going to get a Hancock.
    Olley
  16. Lindy-C
    Lindy-C Deleted User
    Hi Olley
    I may be wrong but Didn't Scotjimland go to Burnt Mill for his tyres for George?
    If it is the same place I recall he was very impressed with their service :Smile:
  17. superk
    Aug 22, 2007
    503
    57
    Devon
    Pleased to be of help Olley :BigGrin:
    By the way if you're looking them up on the web its Hankook - weird I know:RollEyes:
    :Smile:
    Keith
  18. madbluemad
    madbluemad Banned
    Jan 26, 2008
    3,341
    243
    spain
    Linda
    Its really strange that you should say that. The spare wheel on my m/h doesnt fit on to my real wheel either. The hole pitch positions are different.
    I wonder why that would be. I wonder if there is a valid reason for it.
    I have had to get a new wheel impoted from the states. Sorry for moving a tad off topic
    Jim
