Tyre pressures: "Camping" rated vs normal (1 Viewer)
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
I know I'm a bit sad but I like to label up the wheel arches with tyre pressure labels so it's easier to keep tyre pressure in check. Got the manual out (Fiat Ducato 2011/Carado A366) and it states 2 pressure settings depending standard tyres or camping tyres. I've never of camping tyres so I thought I'd better check. The pressures are written as follows,
Standard tyres: 215/70R 15C (109/107)Q
Front 4.25
Rear 4.5
Camping tyres: spec as above
Front 4.75
Rear 5.50
My tyres are Bridgestone Blizzak and no mention of "Camping" so I assume I go with the first settings but as its a large difference I wanted to be sure.
Jim
Ringleader
Jul 19, 2007
36,421
130,921
Sutton on Sea, UK
Adria Panel Van.
Since 1988
The pressure really depends upon your axle weights and particular tyre. The only way to be sure is to go to a weighbridge and get each axle weighed, then call up the tyre maker, tell them the weights and they'll let you know precisely what you should be running at:thumb:
Sep 10, 2011
231
218
West Midlands
Laika Ecovip 309
since 2011 but years in a caravan
Hi Ridgeway,
What Jim said, please see my post you will get the idea. Link Removed
Also there is a good download on this site for tyre info
Link Removed
When you have the axle weights email your tyre maker for the correct psi.
John
Ridgeway
Ridgeway
3,657
6,152
Lausanne
NiBi Arto 85E
Since 2012
OK will try that approach.
Should I weigh with only me in but loaded as normal, fuel, water, kit ?
Dec 6, 2011
11,591
25,420
South Wales
Coach built Adria
load as for your normal trips away, fuel , water if you carry any:thumb:
Stephen & Jeannie
4,174
3,265
Gobowen near Oswestry !!
Sold and bought a Caravan
9 years !!!!
Good piece of kit !!
And when you have done all that......get some of Jims widgets that he is marketing so you are as safe as houses !!!:Cool::Cool::Cool:
1948
444
49
surrey
hymer A class
since 2010
Front 4.25
Rear 4.5
Front 4.75
Rear 5.50
I am no expert, but blow out in a healthy tyre ie. no defects is caused by over weight and under deflation, In doubt always opt for the higher pressure There may be a bit of increased tyre wear in the middle of running surface but I rather have that then an unexpected blow out
