Tyre pressures (again!) (1 Viewer)
longdog
Banned
Apr 16, 2013
255
287
I have a 2009 Ace Adventurer 635EK (same as the Swift Voyager), the hand-book says "see the base vehicle manufacturer's recommended pressures" Fiat recommend 79.1psi all round (which sounds a bit high to me), but on the
Continental Vaneo tyres fitted, it clearly states max pressure 69psi........
So what pressure should I use? I tend to think that Continental know what they are talking about as they made the tyres in the first place. I know the obvious answer is to go to a public weighbridge, note the axle weights and consult the tyre manufacturer, but surely there is a ballpark figure that I can use? I mean the weight varies depending on if I am going away for a weekend or a fortnight, whether my tanks, (fresh, waste and diesel) are full, half-full or empty or indeed anywhere I between.
So what is the collective knowledge on this? :RollEyes:
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
It is best to email Continental with your axle weights, they will respond quite quickly.
Vanco are not original equipment and the door pillar pressures will relate to Michelin that go to 80 psi
funflair
19,356
30,247
Guisborough
MORELO palace
since 2012
You need to check the weights to make sure that the tyre load rating is up to the job, if Fiat say 79psi and the tyres are max 69psi there is something askew somewhere.
I certainly would not go over the manufacturers max rating.
For the record our front axle is about 2100kg and running about 62psi but it depends on tyre size as well 225x75x16.
Martin
DuxDeluxe
14,658
72,784
Planet Zog
A woosh bang van
since 2008
I looked on the Vancos that we just removed (looking for the date) and although it said max 69 psi it also said on the other side of the tyre that as they were camping tyres they could go up to 5.5 bar...... Confusing? Yes. Good idea to email them; they are very helpful
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
The 69psi marking is for the American market (and no - I don't have a clue as to why) but it appears on many tyres of that size and can be ignored.
Techno
Jul 28, 2010
15,475
20,756
May 2010
5 bar is about 70 psi and this is Conti UK website not USA
Broken Link Removed
TheBig1
17,630
43,280
get your axle weights as weighed at the weighbridge and use this table
Link Removed
to work out your optimum pressures
most tyre manufacturers will refer to a similar table to give you their calculation
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
since 1999
Broken Link Removed
I know but that marking appears on a number of different makes. 5 Bar is 72.5psi - so if it was intended to be a max marking you would expect it to be 72 (or maybe 70). The fact that it appears on other makes suggests it is to comply with some standard & I read a while back (vague I know but I can't remember the source - maybe MMM) that it was required for the American market & did not represent a maximum pressure for our side of the pond.
L
longdog
Banned
Apr 16, 2013
255
287
Thanks for the answers, I am guessing that no manufacturer wants to give a ball park figure "just in case".
I can't understand why though. Car manufacturers give pressures for different loads and/or sustained high speed use. What is the problem for MH manufacturers? They know the unladen weight, they also know the maximum laden weight, so why can they not give tyre pressure figures for these two extremes?
SandJ
1,799
818
North Yorks
Too long lol
As stated the 69 is for the American market see reply below
----- Forwarded Message -----
To:
Sent: Fri, 26 Apr 2013 07:32:24 -0000 (UTC)
Subject: Tyre Query
Hello Steve,
based on the 215/70 R15CP 109R ContiVancoCamper and your axle weights the
inflation pressures are:
Front: 4.25 Bar
Rear: 5.5 bar
The 69 psi on the tyre is a marking for the North American market but in
some circumstances the inflation pressure may be higher.
Regards
Mr. Gwyn Fennell
Technical Service Manager UK & Ireland
Continental Tyre Group Ltd
Building DC2
Castle Mound Way
Central Park
Rugby
CV23 0WA
Tel: 01788 566240
Fax: 01788 517731
E-mail: gwyn.fennell@conti.de
www.conti-online.co.uk
http://www.continental-corporation.com
_____________________________________________
This email has been sent from Continental Tyre Group Ltd, a company
incorporated in England and Wales, with company registration number 296602.
The registered office is Continental House, 191 High Street, Yiewsley,
West Drayton, Middlesex, UB7 7XW, United Kingdom.
The information in this email (including any attachments) is confidential
and may be legally privileged. It is intended solely for the exclusive use
of the addressee(s). Access to this email by anyone else is unauthorised.
If you are not the intended recipient, any use, disclosure, copying,
distribution, dissemination or any action taken or omitted to be taken in
reliance on it, is prohibited and may be unlawful. Please notify the sender
immediately if you have received this email by mistake and delete this
email from your system. When addressed to our customers any opinions or
advice contained in this email are subject to our written terms and
conditions of sale in force. You should carry out your own virus check
before opening emails or any attachments. We accept no liability for any
loss or damage which may be caused by software viruses or
interception/interruption of this email (and any attachments). We not
accept responsibility for changes made to this message after it has been
sent, which arise as a result of email transmission or otherwise. Where the
content in this email is personal or otherwise unconnected with the
business, we accept no liability for such content.
Proprietary and confidential. Distribution only by express authority of
Continental AG or its subsidiaries.
The registered office is Continental House, 191 High Street, Yiewsley, West
Access to this email by anyone else is unauthorised. If you are not the
intended recipient, any use, disclosure, copying, distribution,
dissemination or any action taken or omitted to be taken in reliance on it,
Please notify the sender immediately if you have received this email by
mistake and delete this email from your system.
When addressed to our customers any opinions or advice contained in this
email are subject to our written terms and conditions of sale in force.
You should carry out your own virus check before opening emails or any
attachments.
We accept no liability for any loss or damage which may be caused by
software viruses or interception/interruption of this email (and any
attachments).
We not accept responsibility for changes made to this message after it has
been sent, which arise as a result of email transmission or otherwise.
Where the content in this email is personal or otherwise unconnected with
the business, we accept no liability for such content.
Please consider the environment before you print this email.
customer service
EMAIL REMOVED
to:
administrator.technical
23/04/2013
17:20
Hinweis: Diese E-Mail wurde aus dem Kontaktformular von
www.conti-online.com automatisch generiert.
Uebernehmen Sie fuer Antworten an den Absender bitte die unten aufgefuehrte
E-mail-Adresse und nicht 'www@conti.de'. Loeschen Sie diesen Hinweistext
aus der Antwort-Mail.
Note: This email was automatically generated from the contact form of
www.conti-online.com.
In order to reply to the sender please use the email address as listed
below and NOT www@conti.de. Please delete this remark from customer
replies.
Address / Adresse:
REMOVED
Your inquiry / Anfrage:
The Fiat handbook states 5.0 bar front and 5.5bar rear yet the tyres state
69psi max so what is the correct pressure? I have a Besaccarr E450
motorhome on an Fiat X250 Ducato 100MJet XLWB the tyres fitted are
Continental 215/70R15 Cp Max pressure 69psi. The loading is 1850kg front
2000kg rear GVW 3500kg. Thank you for your help regards Steve
Language / Sprache: EN
:thumb::thumb:
