Tyre Pressure (1 Viewer)
ShiftZZ
21,386
84,845
Dark Side of the Moon
Any ideas what your would be for a Fiat ducatto 2003 16in tyres. To dark to go and check th size at the moment
D
Deleted member 29692
Different for each make of tyre. You will get some guesses and opinions shortly but the only way you can get the proper pressures is to email your tyre manufacturers with the details of the tyres and the axle weights (plated weights are OK if you haven't got the actual weights)
Jul 31, 2014
1,930
3,241
West Yorkshire
EuraMobil Activa 820HS
4.5 bar front and 3.5 bar rear depending on load based on 225r16CP tyres but rear is a tag axle so would imagine rear pressure to be higher in single rear wheels
Aug 30, 2012
4,270
11,308
Home of the war horse
burstnar T640
Make sure you are wearing flip flops :happy:
Place lips over tire valve and blow hard when face goes red stop :blusher:
Using a Rapido motion kick tire twice :madder:
do this for all four tires :clap:
:france:
zac
2,614
1,872
Basingstoke
Rapido A CLass 10000
since 2013
ours says 5.5bar all round but then ours is a 4.5t Autotrail Delaware
D
For mine Michelin have said 80 rear and adjust the front according to the actual axle weight. I've got 62 in the front at the moment.
GJH
29,450
38,827
None, now sold
2006 to 2022
This is the table from our handbook. Your van is heavier than ours, Dave, but hopefully the figures will be reasonably close.
Jaws
23,844
72,801
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I used the Mich site to set my pressures when I first got the Autotrail..
Put up with them all last summer..
Then ( whilst looking at other stuff ) got the right tyre pressures from the Autotrail web site..
I had had the rears 20 lbs over the recommended !!
On my tag ( 16" wheels ) the fronts are 75lb and the rears 55lb
Puddleduck
12,387
44,010
Scottish Borders
Without at present
On and off for many years.
No sticker in a door jamb ?
The sticker on our van is for the Fiat base vehicle. There is a page in the handbook which details the pressures for different tyres on the specific motorhome.
You beat me to it Graham. The door jamb sticker is way over what Continental recommend - and now we have the lower pressure the ride is much better :)
