TV power usage (1 Viewer)
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
If the details on the listing are to be trusted, then it is less than 2amps. Or have I misinterpreted your question? :cool:
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
No @ericroy I think you got my q right but if the TV was 1.1 it would make it more attractive to buy than if it was 2amps. So confused to what it draws.
Sep 22, 2013
200
199
Halifax
Relay self-build
Trainee MH owner
From monitoring my own similar Finlux TV, it is not possible to say with that degree of certainty. If you put a sensitive meter in place and measure the current, you will probably see it varying between .9 amps and nearly up to 2 as the picture brightness and sound levels change. I have found that my 22in TV/DVD combo plus the Humax satellite decoder together take under 2 amps on average.
irnbru
irnbru
13,514
31,142
Glasgow
Benimar 264
11 yrs
Thanks but the only reason I would consider buying it was if it only used 1 amp and quality was good.
Looks like I will stick to Avtex. Should be better when I get battery bank increased shortly . Hint hint @rupert :LOL:...or @andy63 :)
