turbo
Discussion in 'Tech/Mech General' started by madozz, May 20, 2009.
  1. madozz
    madozz Read Only Funster
    Feb 18, 2009
    33
    widnes
    hi there
    this might sound like a daft question but i have a eldiss autostratus 2.5 non turbo engine can a turbo be fitted to this.
    man thanks.
    john:Doh:
  2. johng
    johng Read Only Funster
    Aug 15, 2007
    588
    Kent/Sussex UK
    unlikely John, I think the 2.5 was turbo'd from the factory.. but this may have neccesitated crank strength and cam timing issues, etc , fuel pump change, injector change..
    I am willing to be put wrong on this though :) my speciality is the simple old 1.9 psa XUD turbo
    Another John
  3. wildcamper
    wildcamper Read Only Funster
    Jul 26, 2007
    471
    3
    Merseyside
  4. madozz
    Feb 18, 2009
    33
    widnes
    many thanks.
    is there any way to increase the power on this engine then as i find i have trouble on some hills.
    best regards
    john:thumb:
  5. wildcamper
    Jul 26, 2007
    471
    3
    Merseyside
    Hiya,
    You never mentioned what base vehicle it is ??? & year ???
  6. Ruddy
    Ruddy Read Only Funster
    Feb 24, 2009
    99
    Haverhill,Suffolk
    It can be done BUT, You'll need the turbo ecu, injectors,exhaust + turbo manifold, And the big one....lower compression, Which in most case's requires machining of the pistons. And while your at it you might as well replace the rings,big end bearings and main bearings. And dont forget the full gasket set.........:Eeek:
    Its cheaper to find a complete turbo engine and replace the lot.
  7. madozz
    Feb 18, 2009
    33
    widnes
    sorry boss
    its a 1998 peugeot boxer 320
    thanks john
  8. wildcamper
    Jul 26, 2007
    471
    3
    Merseyside
    Hiya John,
    Your luckier than me, my advice would be to change the engine & box completely.
    I could have bought a 2.5TD complete donor vehicle the other day for 500, but mine beening the older model to yours I never had the gearbox :Eeek: but it would have fitted straight in yours with no modifications :thumb:
