turbo problem (1 Viewer)
appydaze
728
1,847
southend on sea essex
Merc high top
20 years
Hi all, Can anyone help? Just got down to South of France and have been plagued with turbo problems on my VW transporter, it cuts out at the most precarious times but if I turn off the engine when I restart it all is well again: it happens at no particular times just at random: HELP!! :cry:
Melchior
129
82
Amstelveen, Netherlands
Alcove
Since August 2012
You say you have turbo problems and that 'it' cuts out.
By 'it' do you mean the engine cuts out (i.e. there is no power, if you press the clutch the engine stops) or the turbo cuts out i.e. the engine still runs but is hugely down on power?
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
Check all the hoses to the turbo and make sure there are no splits or leaks, could be the answer
Good luck
Peter
43,330
49,446
not up on vw's but check the wastegate is free to move usually an armon the side
i'll go with that.....
turbo wastegate atuator sticking......a good spray with WD40 and work the arm and linkage until smooth moving
Minxy
32,656
66,563
E Yorks
Carthago Compactline
I did think of the waste gate valve sticking as we had that problem on our first coachbuilt motorhome but when we did it ran okay but then wouldn't give any power over 60mph, so my money's still on the hoses being the problem.
