Trying fridge on gas (1 Viewer)
May 17, 2016
3,629
7,873
Aberdeenshire
B524
2nd base
I have never tried my fridge on gas until today but the igniter doesn't seem to be kicking in. Works fine on power and all other gas appliances are fine. It's on my old Talbot Express.
Here's a pic of the control panel, can anyone give me a checklist to try tomorrow to see if I can figure it out?
The red switch doesn't light up at all and no clicking. I have been told I should just need to turn the red switch to on - then turn the knob to 3 and push in - this should tell the igniter to start. Does this sound correct?
Jul 29, 2013
9,083
18,761
Salisbury
Hymer B678DL A class
since 2011
You will need to make sure the 12v electrics are switched on as well.(y)(y)(y)
43,399
50,024
The red switch is your ignitor.
Turn the right hand rocker to off if you're on hookup. (center position)
Make sure your 12v hab system is turned on.
Turn the left dial to 3 then press and hold the bottom of the red switch until it turns red.
Hold for 20 seconds (you may have to push the knob in as well for 20 secs, can't remember) then release, it should remain lit.
If it goes out the gas has gone out and you need to wait a few minutes then repeat.
Thats how I remember mine working.
If you never used it it may need a clean and service before it works
Jul 29, 2013
9,083
18,761
Salisbury
since 2011
Not sure in your case but worth a check, I’m sure someone on the forum will be along with a bit more knowledge about your van than me as I’m not familiar with Talbots.(y)
@Wildbill may know.
monzer
May 17, 2016
3,629
7,873
Aberdeenshire
B524
2nd base
thanks @pappajohn I think I've got the starting process worked out but my problem seems to be that the igniter switch aint clicking or lighting up red.
Nov 18, 2011
11,863
43,674
Planet Earth
A van
Over 25 year's
@monzer check the wiring at back of switch I have known the spades to come off if not trace wiring and check for any brakes if not try a continuity check on wiring
bill
43,399
50,024
From memory it will only be lit when the gas is lit... It doubles as an indicator when the gas is lit.
If it ain't lit neither is the gas.
As for clicking, the switch doesn't click, that's the job of the ignitor board which may be deep down at the back of the fridge and wont be audible..... Only the spark may be heard but that's doubtful.
