Truma heating help (1 Viewer)
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
We have friends who we will be meeting at southport on Friday . They have rung to say they can not get the gas heating to work . The van is 2007 auto trail and has truma blow air heating. All they get when trying it is red light on control after about 10 secs. Gas is on and regulator appears fine as Fridge and cooker work ok. Is there a reset anywhere ?
They got the van 4 months ago but only used electric side of the heating till now.
Any other ideas? It's cold up there.
Sep 26, 2013
4,170
5,156
Market Rasen
Self Build
Since 2003
Is there an outside cover on the gas vent for the heater, if there is it needs to be removed.
scotjimland
2,334
10,102
A Woosh bang
persevere.. it can take several attempts to get them lit..
when it fails, switch off, wait a few minutes, re try
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
It does have a reset button... normally round the back of the boiler under a small slidey panel.
Inside the box at the front is the pcb... there are two fuses there that can blow.
(Take appropriate precautions s and disconnect before checking)
The red light means gas isn't working..
It could be the circulation fan that's failed ... also.. check all outlet pipes are connected to boiler.
Also .. make sure there isn't a isolating switch for gas to boiler.
cookie
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
Forgot to add. Neither of them are very tech minded . Slide bits and fuses are over there heads
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
In that case take it to a dealer or mobile repairer or call Truma tbh
Lenny HB
53,440
150,041
On the coast in West Sussex
Hymer B678 DL
Even though the fridge & hob work it could still be the regulator, the heater requires a much higher gas flow.
Gellyneck
9,235
18,210
Scotland
More than toes wet now!
As @sdc77 says there are individual isolating valves for all the gas appliances, fridge, cooker, heating and external gas point (if fitted). Worth a look to see if they're all on.
cookie
Jul 10, 2016
414
385
hucknall
Swift bolero 712sb
10 years
Hopefully they won't be frozen to death by the time we get there lol
