Truma Heater problem (1 Viewer)
Loujess
3,123
3,086
Leeds UK
none
It works fine on gas and the fan is working perfectly, just no heat on EHU.
It's not the end of the world since we do have a little fan heater.
Ivy
wasp
1,724
18,180
Warsop
None gone caravannin
If you have it on ehu the fan cools the warm air so it is not advisable to have it running, just have the heater on:thumb::thumb::thumb:Cheers Rob W
Loujess
Loujess
3,123
3,086
Leeds UK
none
Yes to Mixter, I do have it on leccy setting. Honestly, do you think I'm a daft nellie? I might be sometimes but not at the moment.
And Rob, I'm a bit confused now. Why have a fan if it cools the warm air? I thought it was suppose to circulate the warm air. The fan circulates the gas-warmed air ok. I wonder if an element or something needs replacing and if we should take it to a Truma agent.
Ivy
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
We have had similar, its great (the ehu) till you put the fan on. The advice is leave it on for 15 minutes before putting the fan on, we left it longer and the fan driven air soon goes from warm to cool, much better heating from just the heater alone when on leccy (in fact it gets so warm sometimes you need to turn it off). Fan is fine with gas heating. I have not asked the dealer about this yet, busy sorting other niggles.
Why/how this is the case I have no idea - seems illogical - but reality can be sometimes.:Confused:
Loujess
Loujess
3,123
3,086
Leeds UK
none
Thanks for that. I'll try and give it a try tomorrow and let you know how it goes.
Ivy
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
It would help to know which type of Truma heater you have. As far as I know only the S type heaters can be used on electric without the fan running.
D.
Jan 11, 2010
2,747
9,576
Chester
Auto-trail
Well that`s our 13th year & still loving it.
heater
Hi Grumps is right on the money with this, we use ours just the same, turn heater on at it`s highest setting for 15/20 mins and then turn the blower on we tend to run the fan around number 3 that gives a lovely warm back ground heating.
We also don`t have all the vents open. :thumb:
Loujess
Loujess
3,123
3,086
Leeds UK
none
Well thanks to everybody. I tried it yesterday without the fan and it worked perfectly.
Ivy
