truma combi 4000e problem
Discussion in 'Tech/Mech General' started by seanoo, Jan 10, 2015.
  1. seanoo
    seanoo Funster
    Nov 14, 2009
    368
    224
    normandy
    hi , the guy parked next to me has a problem with his water heater. he says his batteries dropped below 11 volts and the heater cut out ,then he took the van for a spin and also gave them a good charge from his solar but since then his truma combi won't work at all. his batteries are up to 13 v now and i have checked the fuse but there still seems to be no power there at all. anyone have any ideas? cheers sean.
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,201
    3,028
    Kendal, Cumbria
    Does any other 12v kit work?
  3. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,991
    West Norfolk
    Switch off the heater and pull the fuse!
    It worked on the In Laws van!
  4. dabhand
    dabhand Funster Life Member
    Feb 19, 2014
    1,568
    2,782
    Staffs
    Similar thing happened to me, assumed it was an electrical problem because I jump started the van and blew some fuses, long story short after much arsing around, found that mice had chewed through a feed cable under the drivers seat!!
  5. seanoo
    seanoo Funster
    Nov 14, 2009
    368
    224
    normandy
    All other bits work
  6. seanoo
    seanoo Funster
    Nov 14, 2009
    368
    224
    normandy
    I will have a look and pull the fuse tomorrow , cheers
  7. jonandshell
    jonandshell Funster
    Dec 12, 2010
    5,286
    7,991
    West Norfolk
    I pulled all the fuses at the main distribution panel on the In Law's van.
    On theirs it was supplied via one of the 'aux' fuses.
    The heater could be supplied from anywhere on yours.
    Remember to reset the auto drain valve afterwards!
    • Like it Like it x 1
