Truma c 3402 hot air supply
Discussion in 'Heating and Air-Conditioning' started by Muffinn, Apr 17, 2008.
  1. Muffinn
    Muffinn Read Only Funster
    Apr 17, 2008
    31
    Worcester
    Can I ask a couple of questions about my motorhome heater fitted to a 2003 CI Cipro Garage?
    1. There is a duct into the garage from a short pipe which really effectively blasts hot air. The one into the lounge area on a longer pipe is very ineffective. Does anyone know if I change the balance? As I do not want to heat the garage ever can I get some sort of blanking plate for this outlet?
    2. Should the cream pipes that duct the air be fixed into the outlet sockets on the boiler as they seem just pushed home?
    Any thoughts?
  2. Pammy
    Pammy Funster
    Aug 3, 2007
    900
    119
    Mansfield
    Hi Muffin
    Can't see the person on line tonight that may have been able to answer your question but click on the link below and contact Truma direct.
    I was looking for 'Raoul'. He's a certificated LPG gas engineer. You could pm him and he will probably pick it up tomorrow unless he comes on line during the evening.
    www.trumauk.com/schematics-and-part-numbers/heating-schematics/trumatic-c-3402-c-
    Pammy
  3. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,790
    6,053
    Mansfield,Notts
    Hi welcome to the fun site,
    Yes you can play with the outlets as much as you wish, they are just a push fit in most cases, you could if their
    forever popping out, put a couple of self tappers through, I would be tempted to reverse the two pipes IE put the lounge pipe onto what appears to be the hotter outlet first, and the garage on the other, if that doesn't help I would still leave a trickle feed of air to the garage rather than blank of completely, be sure to use a non flammable material to blank of any ducts
    Geo
  4. Muffinn
    Apr 17, 2008
    31
    Worcester
    Thanks for the welcome and the help!
    Thanks for this. I thought I read somewhere that for some models at least there is a blanking device for an unwanted outlet. I'll check with Truma. I'll also check with them how you can extend pipes too as I will need to do this to swap pipes over.
  5. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,105
    17,778
    YO11 2BD
    my carver heater hot air outlets have a flap inside to control airflow.
    just open or close as needed.
