Travelling with water in the flush tank (1 Viewer)
Touchwood
772
733
NE England
Compass Avantgarde 140
5 years and learning
New one on me, this - on reading the handbook with our new purchase (Compass Avantgarde 140) I find that there are dire warnings about not travelling with water in the flush tank - I quote: -
"Please note that Thetford recommend not to travel with water in the flush tank of the C400 bench cassette toilet.
When entirely necessary, up to 2 litres can be added to the flush tank giving you enough water for 2 flushes......
.....Please be aware that travelling with more than 2 litres of water n the flush tank can cause water damage to both the toilets compartment and to the Motorhome itself as water can escape from around the flushing mechanism"
Now, I'm not bothered about only having a couple of flushes available when travelling, I do frequently need a pee during a journey (age problems) but 2 is enough. This however does pose some logistical problems for emptying/refilling the flush tank every time we relocate the 'van - frankly it's going to be a pain.
Anyone else got this problem? Or can I ignore it? The dealer obviously wasn't aware of it, the flush tank was full when I collected the 'van.
Bartyfixedit
330
566
Maidstone Kent
Self Build Ducato L4H3
Since 1987
I've always travelled with whatever is in it. I usually start a trip with it full. Never had a problem.
Travelling with a soil tank over 50 % full is also supposed to be a no no. I do try to adhere to that one.
53,675
150,921
When we had caravans that had separate flush tanks always used to travel with tank full never caused any problems.
Bailey58
8,842
29,858
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
Are we talking a different system? A litre per flush? Mine gets a quick squirt after a pee and the tank lasts for at least three empties of the cassette.
Touchwood
Touchwood
772
733
NE England
Are we talking a different system? A litre per flush? Mine gets a quick squirt after a pee and the tank last for at least three empties of the cassette.
Yes, me too. Hadn't quite spotted how silly that was, makes me wonder about the rest of the advice.....
Riverbankannie
10,596
61,976
Bristol
IH 630 RL PVC
Happen to have my Thetford manual to hand. It's a C-402/ 403 and varient.
It says do not travel with a flush tank that is too full (we advise empty but for sure not more than half full)
I think they are just covering themselves for any claims. ( Customer: Oy Thetford, my MH damp due to your leaking, not fit for purpose, product. Answer: well we told you not to travel with any water in it!)
I have always travelled starting off with full flush!
The part to be aware of is the glass inspection tube. If that gets loose, then water everywhere.
53,675
150,921
Yes, I agree, if it supposed to be designed for MH, it should by definition be ok when on the move.
Surely the separate tank ones are intended for caravans nearly all Motorhomes the flush is fed from the main water tank, more a case of the converter not using the right product for the job.
Does it really matter, we camp off grid a lot so use a spray bottle to flush 1Lt lasts days and preserves our precious water supply and gives longer times between emptying the loo.
GJH
29,450
38,827
None, now sold
2006 to 2022
There was a similar warning with our Autoquest 100 but I'm sure it was only about over filling. I never had any bother. It should be no different from the system in your previous van.
Touchwood
Touchwood
772
733
NE England
Thanks to all, I think I'm going to follow the trend and ignore the hand book!
Feb 16, 2013
19,767
52,175
uttoxeter
ambulance conversion
50 years
We have the same one and had it break last time out, so got the top off to have a look , there was that much mastic around it I doubt it would leek, anyway the plunger is fastened on with three little plastic clips and one had broke off, so super glued it up and put it back together , haven't tried it yet but they are only £20 if it breaks again so shall replace it if it does, but back to the op , can't see it leaking and ours is always full no problems(y):)
Jan 27, 2013
1,334
871
Stamford
Benimar Mileo 282
Seven plus years
On a practical level the exterior filler flap doesn't have good seal so pink water can/does escape if it's sloshed about.
Weight could an issue with a single screw at the top.
And perhaps the water might get out if there's a gap between filler and tank.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
We rarely put water in our flush tank now, as most of our motorhome use is off grid with no Elsan point available (hillclimb and sprint race tracks) we don't want to fill the cassette too quickly. We simply use a hand spray bottle filled with a mix of water and pink toilet flush additive to rinse the bowl round after use. Using this method and utilising the on site toilet facilities we can last up to four days before the cassette needs emptying (bio washing tab in cassette as well.
D.
Sep 12, 2016
2,275
5,052
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
Well another little snippet of information that is daft and will be stored as such
Our caravan loo has a mechanical flush (after all the caravan is 13 years old and the electric flush is newer) so we can plunge as much or as little as it needs but the handbook (by Thetford) says similar dire warnings of travelling with a full tank and causing a spillage)
BUT we stopped using Flush liquid additives years ago simply as they react chemically with the Bio fluids and cause a black scale like lining to the waste cassette which only comes off with Steradent - - Without the pink expensive rubbish no black lining
But this is where we all seem to agree that the toilet header tanks are made for moving vehicles and so should be watertight
