Transit radio aerial. (1 Viewer)
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
I am now on my second radio in our van and still I can only get decent reception with a very strong signal, most of the time I get varying levels of interferance ranging from niggling to switch the radio off. Any suggestions for an aerial to replace the standard Ford one.
I have isolated and dealt with the 12volt to usb charger problems.
Dec 12, 2010
5,411
21,562
Cumbria
since 2011
I think @Addie from motorhomewifi did a blog somewhere about fitting an active aerial to his van. I read it just after I'd installed my solar panel and couldn't face taking all the cab trim off again to do it, though the reception on mine is terrible too.
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
My radio reception can be poor due to the Ford ariel. My solution is to unscrew the whip and squirt some WD40 into the stub and whip thread and reconnect. Seems to work, I do it each year and so far so good
Stonemags76
1,280
3,994
Derbyshire Dales
Auto Sleepers Warwick Duo
Full Time 2011-2013, now part timers!
We have the same problem - great reception when stationary but rubbish when moving. Our aerial seems to be attached to the wing mirror housing, and after a quick look hubby couldn't see that it would unscrew without dismantling the whole thing, so he left it for now. Funny thing was, the signal was better on the next journey! Hope it stays like that, cos I find it really annoying! Our last van was the same (ducatto), and we never did get a solution! How hard can it be for covertors to ensure a decent radio signal! Even rubbish on the M25, and I get cross on there anyway! OK - rant over!
Sep 10, 2013
1,187
18,697
Chelmsford Essex
Getting better
Mine is the rubbery whip mounted off the near side mirror. Tell hubby to just give it a good twist with a pair of pliers or grips, I put some rag on the jaws to protect the rubbery bit.
maxi77
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Took the wire aerial of the mounting and it seemed to have something likethread sealant on it. Have cleaned it up with a tap and die and applied the WD40. Away this weekend so will seehow it goes.
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
Have same trouble with our skoda fabia. I took the rubber aerial off cleaned it , put wd40 on it and did not make any difference to the reception at all. Have given up and do not bother with a radio now.
