Trailers (Not Films) (1 Viewer)
Another Lesley
138
117
North East
Since 2010
I have the Motorhome ::bigsmile:, bought a dainty little Hyundai to tow behind,::bigsmile: now all I need is a trailer for it. Does anyone have any recomendations of a good maker/supplier please? I live in the North East so would prefer one a bit local. Also....is it easy to drive onto a trailer? I have never done it and confess to being a tad nervous.:Blush:
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
Brian james and ifor williams are the market leaders but not sure where either are situated
43,329
49,444
cant help with a supplier Lesley, but i couple of points to check on.
VOSA are stopping more and more motorhomes to check weights and if overlaoded they can stop you going any further and fine you.
so you should check your maximum trailer allowance.
it should be on the chsssis/vin plate under the bonnet.
deduct the GVW (usually the top number) from the train weight GCVW (usually the bottom number), the answer is the total trailer allowance which includes the trailer load and the trailers own weight.
the trailers maximum loaded weight is the figure which is required....even if it isnt loaded.
i would suspect your trailer allowance will be around 2000kg.
point two....your licence
if you took your test pre jan 1997 you should be able to tow a trailer of just about any weight if the tow vehicle allows that weight.
post jan 1997 you need to take a separate trailer towing test to tow over 750kg
Feb 22, 2008
12,265
45,050
Norfolk
Nearly Tugging
Since 2004
I have a Brian James Trailer for my Peugeot 107, a quality unit , picked it up from their premises at Daventry.:thumb:
www.brianjames.co.uk/
PS in UK I normally use an A Frame for convenience
duane0001
792
778
East Coast, North Yorks
Expedition 67 soon!
2021 This time
Well the law on towing post Jan 97 is 750kg
But you can tow a heavier trailer if the combined weight is no more then 3500kg
But I guess that would mean one small motorhome :ROFLMAO:
Feb 22, 2008
12,265
45,050
Norfolk
Nearly Tugging
Since 2004
The GVW might be 3500kg but the GTW will be more and could possibly allow a trailer above 750kg.
Addie
Trader - Motorhome Wifi
Oct 15, 2011
553
834
York
If you passed your test post Jan 97 but pre Jan 13 you can tow a trailer upto 750kg behind your 3500kg Motorhome (a total weight of 4250kg). The ability to tow a 750kg trailer on a 3500kg van was removed in Jan 2013.
In both situations you can tow a trailer exceeding 750kg but then the combined weight of 3500kg does apply - as no doubt it would apply to the OP if he is towing a car on a trailer.
https://www.gov.uk/towing-with-car/driving-licence-rules-and-what-you-can-tow
Geoffers
506
215
Groby Leicester
Might be worth hiring one for a day,usually about £35, see how you get on.
We used a trailer for the first time last week and found it a bit of a pain ,especially strapping the car on in the rain. At least by hiring one you can test your confidence before buying as they are not cheap!
P.S. we went down the other route, but I won't start that discussion again :Doh:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Don't forget that your towing limit will have to be for both the car and the trailer. A lot of motorhomes are close to the limit just with a car on an a frame, especially if the GVW has been uprated. Every increase in GVW comes off the towable weight (the train weight stays the same). This is why tag axle vans can tow very little if anything.
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
also take in to consideration what the trailers gross plated weight is as if this is higher than the difference between the gross weight and the gross train weight of the towing vehicle you are automatically over weight even if the trailer is empty.
