Towing Suzuki jimny.
Discussion in 'Motorhome Chat' started by walter senior, Aug 5, 2011.
  1. walter senior
    walter senior Funster
    Jan 7, 2011
    62
    44
    forgue aberdeenshire
    :Rofl1::Rofl1::Rofl1:
    Hi. as any one used a jimny as a tow car behind their motorhome i have a 30 ft iveco i have used a citroen. saxo and a vauxhall. astra1.7 td. with no problem. but you hear all sorts of things about the jimny i have had one for 4 years but never towed it with the motorhome fitting the bracket for the a. is not a problem hope some body as some feed back about this matter. thanks a lot.
    walter:Rofl1::Rofl1::Rofl1::thumb::thumb::Blush::Blush:
    :Rofl1::Rofl1:
  2. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    just watch it doesn't fall over going round roundabouts :Rofl1::Rofl1::Rofl1:
    • Like Like x 1
  3. walter senior
    Jan 7, 2011
    62
    44
    you never know.
    :Rofl1::Rofl1::Rofl1:good point aba. at least i will not be in it thanks.
    walter.:Cool::Cool::Cool:
  4. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,687
    17,299
    YO11 2BD
    not sure as i've never looked but they may still be using the SJ series running gear....i know the Vatara did.
    if so, you need free wheeling (manual or auto) front hubs so the transfer box doesnt get wound up.
    i use to pull my SJ410 behind the landy disco with no trouble
    • Like Like x 1
  5. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    I'm almost sure that in normal road going use the Jimny is two wheel drive and the driver can (electronically by means of two innocuous buttons on the dash ) select 4 x 4L or 4 x 4H whenever the need arises. If that's so the transfer box would normally be disengaged and there's no need for free wheeling hubs ..... I think
    • Like Like x 1
  6. walter senior
    Jan 7, 2011
    62
    44
    :thumb::thumb:
    Hi. Quire. my jimny as a small gear stick with High. low. and neutral. i think in neutral its just like a rear whell drive car . Walter.:thumb::thumb::Blush::Blush:
  7. pappajohn
    Aug 26, 2007
    29,687
    17,299
    YO11 2BD
    as i said in my other post im not 100% sure but it does sound like the old SJ series transfer box.
    permanant 4wd with free wheeling front hubs for road use....in effect rear wheel drive but power is still sent to the front axle even though it doesnt drive the hubs until the rear wheels start to spin.
    neutral position on the transfer box disconnects all drive from the engine to both axles but the axles are still linked to each other in the trans box.
    for towing....transfer box in neutral, main box in neutral, front hubs unlocked, very important, if manual locking (manual hubs have a 1/4 turn lever in the hub center, auto hubs have a plain hub center)
  8. walter senior
    Jan 7, 2011
    62
    44
    Hi Pappajohn. a bit lost with this my hubs have a plain center so think thay will be auto hubs so what do you think will i be ok to tow it. thanks. Walter.:thumb::thumb::thumb:
  9. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,720
    Mid Cornwall
    Early ones, Yes - later ones No!:thumb:
  10. pappajohn
    Aug 26, 2007
    29,687
    17,299
    YO11 2BD
    one way to find out.....
    jack up one front wheel only and try turning it in the normal direction of rotation.....forward.
    if it turns fully and freely it has auto hubs (which it sounds like yours are) and can be towed.
    if it turns a limited amount only then gets tighter and tries to spring back, it has permanant 4wd and cant be towed.
