Towing an Automatic car with 'A' Frame
Discussion in 'Tech/Mech General' started by davidallan, Mar 17, 2009.
  1. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    Greetings everyone. Having towed an Auto SMART car[disabled driver / auto only] with an 'A' frame for a couple of years now we are looking for any other AUTOMATIC cars being towed by the 'A' frame method.........Make & Model of your AUTO being towed will be very very helpful. There must be plenty out there??
    Thanks very much....
  2. Bryan
    Bryan Read Only Funster
    Jul 19, 2007
    2,096
    342
    Auto Jeep Commander can be towed on an a-frame :Wink:
  3. dazzer
    dazzer Read Only Funster
    Jul 30, 2007
    1,698
    99
    In my house
    Jeep Grand Cherokee Auto on an imported USA A frame and Brake Buddy :thumb:
  4. brianju
    brianju Read Only Funster
    Sep 18, 2007
    171
    35
    Hampshire Hogs now in Mid Wales
    Hi davidallan
    We are towing a Suzuki Grand Vitara 3dr 1.6 auto
    Unsure whether the later models can be towed?.... ours is on a '51 plate
    Cheers Brian
  5. scotsy
    scotsy Read Only Funster
    Feb 13, 2009
    13
    auto?
    I'm new to this game but surely ANY car that is front wheel drive and doesn't make the combined unit exceed it's 'train' weight etc could be towed on an A frame without other mods. :RollEyes:
  6. michaelc
    michaelc Deleted User
    In answer
    HI, not all autos can be used on an A frame, it all depends on the oil feed to the gear box, many auto boxes lock the clutch plates when on the move and this will wreck the gearbox if used on an A frame, If you tow automactics you may over pressure the gearbox oil and blow the seals. this is why you saw many auto,s being towed with their rear wheels off the road or placed on a trailer.
    michael
  7. Thepips
    Thepips Trade Member
    Sep 26, 2007
    500
    Basingstoke
    Conventional torque converter automatic gearboxes are likely to be damaged by being towed. Our Citroen Pluriel uses their sensodrive paddleshift five-speed sequential gearbox. It's actually a manual gearbox with a conventional clutch so it's fine to tow.
    Regards
    Doug
  8. davidallan
    davidallan Funster
    Oct 22, 2007
    116
    37
    Leeds
    PLEASE keep these experiences coming........Citroen senso-drive OK... Thats about the size I need .., and more importantly i'm sure other members will be interested in the RESULTS & COMMENTS....
    WHAT ELSE IS OUT THERE IN 'TOWABLE' 'A' frame automatics..?????????????
    Interesting results from a few main makes/dealers enquiries has resulted in a resounding NO YOU CANNOT TOW THEM !
    Even the 'Smart Car ' Handbook says you cannot TOW it with all wheels on the ground.
    Thank goodness we have such sites as this ;where direct experiences give straight forward answers..................MANY Thanks Davidallan
  9. Bryan
    Jul 19, 2007
    2,096
    342
    Hi,
    I know it's probably too big for you considering the comments you have made but just for information, the Jeep Commander Auto instruction book not only says you CAN tow it but also tells you what to do to tow it in a section called "Towing all wheels down e.g behind a motorhome"
    HTH
    Bryan
  10. muz
    muz Read Only Funster
    Nov 15, 2007
    133
    4
    eastwood notts
    auto
    hi,i have a mercedes vaneo 1.6 petrol with a manual gearchange but no clutch pedal so its just the same as an auto.i tow it on an a frame.i am also disabled and have a crane in the back of the vaneo so ive got the best of both towing and the camper,it does 35ish mpg,and its rearly nice to drive [and easy].hope this helps.muz
  11. brianju
    Sep 18, 2007
    171
    35
    Hi again
    Just for the record ....... our Suzuki manual says - you can tow 4WD auto four wheels down and gives instructions under Recreational Towing.
    Brian
  12. scotsy
    Feb 13, 2009
    13
    I told you i was new:Rofl1:
    I thought an A frame was the dolly type thing where the front wheels are off the ground...
    note to self.."read the post properly before diving in with a reply":RollEyes:
    Sorry OP:thumb:
  13. dazzer
    Jul 30, 2007
    1,698
    99
    In my house
    You can tow any 4x4 as long as it has a neutral position in the transfer box (the 2nd gearstick with high and low range on it!!):thumb:
  14. TeeMyob
    TeeMyob Funster
    Jul 18, 2009
    608
    406
    Cheshire NW UK
    Tow
    So do you think I could tow a 1990-2000 Toyota Previa with Auto box?
    TM
  15. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,389
    18,078
    YO11 2BD
    no it isnt Muz...you have an auto clutch which is totaly different to an auto box.
    a manual box doesnt rely on oil pressure and electronics ...auto's do.
    you select neutral on your car and the engine is completely disconnected from the output shaft to the drive wheels...
    an auto relies on oil pressure from the input shaft and driving the gears, via the output shaft from the drive wheels when towing, will not produce any pressure.
    no pressure...no lubrication....no gearbox :Eeek:
  16. pappajohn
    Aug 26, 2007
    30,389
    18,078
    YO11 2BD
    or manual/auto disconnect front hubs...suzuki, toyota etc
    landrover are permenant 4WD and cant be flat towed at all.
